Intel® Atom™ Processor Series |
Devices |
64-bit Support |
Hyper-threading |
N270, N280 |
Netbooks |
No |
Yes |
N4xx series , N5xx series |
Netbooks |
Yes |
Yes |
D4xx series, D5xx series |
Entry level desktops (e.g. nettops) |
Yes |
Yes |
230, 330 |
Yes |
Yes |
Z5xx |
Mobile Internet Devices (MIDs), some netbooks |
No |
Yes (except Z510) |
Z6xx |
No |
Yes |
CE4100 |
Consumer Electronics (e.g. Internet TV) |
No |
Yes |
E-series |
Embedded |
No |
Yes |
Extended Family |
Extended Model |
Type |
Family Code |
Model No. |
00000000 |
0001 |
00 |
0110 |
1100 |
Процедура определения процессора:
struct CPUInfoStruct { union { char CPUBrandString[48]; __int32 nCPUBrandString[16*3]; }; int nSteppingID; int nModel; int nFamily; int nProcessorType; int nBasicProcessorID; int nExtendedModel; int nExtendedFamily; bool bAtomProcessor; bool bHyperThreading; char CPUString[13]; }; bool isAtom( const CPUInfoStruct& info) { // firstChar is beginning pointer, c is end minus the string // length we're looking for char const * firstChar = info.CPUBrandString; // Atom(TM) = 8 chars char const * c = info.CPUBrandString + sizeof(info.CPUBrandString)/sizeof(char) - 8; // search backwards, looking for 'A' 't' 'o' 'm' '(' 'T' 'M' ')' or till // we hit decrement past firstChar while ( c >= firstChar ) { if ( c[0] == 'A' && c[1] == 't' && c[2] == 'o' && c[3] == 'm' && c[4] == '(' && c[5] == 'T' && c[6] == 'M' && c[7] == ')' ) { return true; } --c; } return false; } // This function fills up the CPU Info Struct for us. // multiple CPUID calls are necessary to get all the information and // each call gives you more information about the depth of calls you can make. void fillCPUInfo(CPUInfoStruct& info) { __int32 CPUInfo[4] = {0}; ::memset(&info, 0, sizeof(CPUInfoStruct)); // cpuid intrinsic calls the cpuid instruction and returns 4 32bit values // the results depend upon the InfoType parameter passed in // Get the number of maximum InfoType value we can call for this // processor and also get the ID string ::__cpuid(CPUInfo, 0); // Swap last two to put in readable form int temp = CPUInfo[2]; CPUInfo[2] = CPUInfo[3]; CPUInfo[3] = temp; // Copy 12 characters ::memcpy(info.CPUString, &(CPUInfo[1]), 12 ); // 13th position is zero // Check to see if we can make the next call if( CPUInfo[0] < 1 ) { return; } // Call with InfoType == 1 // CPUInfo will be set to the following: // 0: Bits 0-3: Stepping ID // 0: Bits 4-7: Model Number // 0: Bits 8-11: FamilyCode // 0: Bits 12-13: Processor Type // 0: Bits 14-15: Reserved // 0: Bits 16-19: Extended Model // 0: Bits 20-27: Extended Family // 0: Bits 28-31: Reserved // 3: Bit 28: Hyper-threading technology ::__cpuid(CPUInfo, 1); info.nSteppingID = CPUInfo[0] & 0xf; // bits 0-3 info.nModel = (CPUInfo[0] >> 4) & 0xf; // bits 4-7 info.nFamily = (CPUInfo[0] >> 8) & 0xf; // bits 8-11 info.nProcessorType = (CPUInfo[0] >> 12) & 0x3; // bits 12-13 info.nExtendedModel = (CPUInfo[0] >> 16) & 0xf; // bits 16-19 info.nExtendedFamily = (CPUInfo[0] >> 20) & 0xff;// bits 20-27 info.bHyperThreading = (CPUInfo[3] & 0x10000000) != 0;// bit 28 // Check to see if we can get the Processor Brand String // Call with InfoType == 0x80000000 ::__cpuid(CPUInfo, 0x80000000); if( CPUInfo[0] < 0x80000004 ) // extended info supported up to 4? { return; } // Yes, make the 3 calls (16 chars each or 4 ints each) // to make up the brand string - it's null terminated ::__cpuid(info.nCPUBrandString + 0, 0x80000002); ::__cpuid(info.nCPUBrandString + 4, 0x80000003); ::__cpuid(info.nCPUBrandString + 8, 0x80000004); // Now we can check for Atom(TM) processors info.bAtomProcessor = isAtom( info ); } int _tmain(int argc, _TCHAR* argv[]) { // This is how to use the code CPUInfoStruct info; // Create the struct fillCPUInfo(info); // Fill it // Query the bits printf_s("CPUString : %s\n", info.CPUString); printf_s("Brand String : %s\n", info.CPUBrandString); printf_s("Hyperthreaded?: %s\n", info.bHyperThreading ? "Yes": "No"); printf_s("is it an Atom : %s\n", info.bAtomProcessor ? "Yes": "No"); return 0; }
Вложение | Размер |
Intel-Atom-Block-Diagram.png | 231 КБ |
у меня по етому поводу два вопроса :
- какими из открытых источников вы пользуетесь
- присутствует ли в Атомах - АМТ, или планируется ли
с уважением
судосборщик, ЧСЗ
... иди туда, незнаю куда, возьми то, не знаю что ... (C) Русские народные сказки
