Не стартует с пропатченой прошивкой. Потом патчил всегда
Не стартует с пропатченой прошивкой. Потом патчил всегда исходник производителя. Первый раз патчил без ключей патчером версии 4.12
Лог работы Bios pather
BIOS Patcher ver. 4.23.
Found 2Mbit BIOS (4.5x)!
1. New CPU Support : not found.
2. P3-detect error : not found.
3. New Koeffs Support : not found.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : not found.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : Warning! Not found "genu"!
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.15 (C)Award Software 2001 All Rights Reserved.
Adding modul.tmp 13.5%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
(c)2002-2003 apple_rom, www.ROM.by
Лог до патчера
******** 1007.004 BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
================================================================================ 0. System BIOS E6808B28h(-417757.22K)AE7977Dh(178661.88K)Єq
еґъ `»aДђеґ‹ЖOдKЯЧУВ¶г°1‡ ѕOз
Total compress code space = AE9977Dh(178789.88K)
Total compressed code size = AE7977Dh(178661.88K)
Remain compress code space = 20000h(128.00K)
** Micro Code Information **
Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID
Лог после патча
1. Other(4E00:0000) 00E6Eh(3.61K)00217h(0.52K)modul.tmp
2. Other(2E22:0000) 00020h(0.03K)00041h(0.06K)start.tmp
3. CPU micro code 09800h(38.00K)05525h(21.29K)cpucode.bin
4. Other(2A6A:E528) 6C310CC3h(1772611.25K)15E3385Dh(358606.09K)Э%Jщщ№М¦vnlў
Total compressed code size = 20CB2757h(537289.81K)
Remain compress code space = EA1E7026h(-358499.97K)
------------------+--------------------+--------------------+-------------------PPGA 01 06B4| PPGA 1C 06B1| PPGA 01 068A| PPGA 08 0686
SLOT1 07 0686| PPGA 14 0683| SLOT1 13 0683| PPGA 11 0681
SLOT1 0D 0681| SLOT1 0E 0673| SLOT1 10 0672| PPGA 03 0665
SLOT1 0A 0660| SLOT1 10 0653| SLOT1 2A 0652| SLOT1 40 0651
SLOT1 40 0650| SLOT1 35 0634| SLOT1 34 0633|
С пошаговым пробовал уже после неудачной прошивки и проверить уже нет где. При пошаговом дает только один запрос. а все остальное автоматом.
