I didnt want to make the cpu mobile because of my linux partition. but i got SUCCESS!!!Finally after many hours of testing and messing around with the L bridges i got 17x112=1905Mhz(2300+) or 18x107=1926Mhz(2400+)!!!And STABLE!! I make some tests to see which mode is actually faster.
Unfortunately, my system refuses to boot with a higher multiplier, even 19x.I raised core voltage to 1.85V but still the same.(however now it shows me 1.7-1.75V in the bios...!)
Is that possible to boot at a higher multi with the mod u mentioned????????
However,I guess that the problem is that the core is thouroubred A, not B or barton.
Maybe with a not superlocked t-bred B or barton 2500+ (1833mhz), i could get an 24x100=2400Mhz (3400+??) or even a 24x112=2688Mhz(3700+????) !!!
Has anyone of u gone that far???????
However, it seems to me like a nice ugrade from a duron 700@970Mhz with just 60-70 Euros!!
Maybe if i make the cpu mobile(but still booting at 18x) i can get a vcore of 1.9-2.0 V and so more Mhz! What do u think??????
:P
p.s. Do u know if new semprons can be trasformed into mobiles with the same trick??????
:P
