Все проги скачаны с этого сайта c:\bp 1.bin /s
c:\bp 1.bin /s /v
report.txt:
BIOS Patcher ver. 4.23.
Found 1Mbit BIOS!
Remove "otkat" (backup key)
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : is not needed to be fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Adding timings-tweak.Adding "Turbo RAM"-tweak.
Write Allocate addinng: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: -> fixed.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 34.1%
Adding start.tmp 87.5%
