Вот Лог работы патчера
BIOS Patcher ver. 4.23.
Attention! Advanced
13 Окт 2005 - 11:35 Unknown BIOS
Found 2Mbit BIOS (4.5x)!
1. New CPU Support : -> fixed.
2. P3-detect error : -> fixed.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : -> fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.15 (C)Award Software 2001 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.15 (C)Award Software 2001 All Rights Reserved.
Adding modul.tmp 32.2%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
(c)2002-2003 apple_rom, www.ROM.by
Линк на прошивку (нашел пока такой)
ftp.stack.ru/drivers/BIOS/Elite/P6BAT-B/batb17a.zip
