Вот вывод патчера:
C:\bios>BP-4_23.EXE 5DVX_19U.BIN
BIOS Patcher ver. 4.23.
Found 1Mbit BIOS!
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : is not needed to be fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Write Allocate addinng: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix:CBROM V2.07 (C)Award Software 2000 All
Rights Reserved.
Adding modul.tmp 31.6%
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding start.tmp 87.5%
(c)2002-2003 apple_rom, www.ROM.by
Но прошить биос я так и не могу!
В Мануале абсолютно не описаны перемычки которые мне нужны.
The following jumpers are for functional testing. Normally, you did not need
to change this settings
JP10=2-3, JP11=OPEN, JP12=2-3, JP13=1-2, JP14=2-3
*Optional features, Contact your supplier for latest information.
Все что есть в мануале. Другие перемычки по другой теме, типа вольтаж проца, частота проца, частота шины.
Где ж ты нужная инфа?
Вот вывод патчера:
Found 1Mbit BIOS!
Rights Reserved.
