Cisco 2970
Мигнул свет. Аккумуляторы в UPS не выдержали и Subj начал циклически перезагружаться...
Base ethernet MAC Address: 00:0e:84:03:41:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 128 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5406208
flashfs[0]: Bytes available: 10592768
flashfs[0]: flashfs fsck took 8 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c2970-i6l2-mz.121.14-EA1a/c2970-i6l2-mz.121.14-EA1a.bin"...@@@@@@
File "flash:c2970-i6l2-mz.121.14-EA1a/c2970-i6l2-mz.121.14-EA1a.bin" uncompresse
d and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) C2970 Software (C2970-I6L2-M), Version 12.1(14)EA1a, RELEASE SOFTWARE (
fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 02-Sep-03 02:23 by antonino
Image text-base: 0x00003000, data-base: 0x00681E70
Initializing flashfs...
flashfs[1]: 128 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 5406208
flashfs[1]: Bytes available: 10592768
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
cisco WS-C2970G-24TS-E (PowerPC405) processor (revision B0) with 118774K/12288K
bytes of memory.
Processor board ID CSG0750P05H
Last reset from power-on
1 Virtual Ethernet/IEEE 802.3 interface(s)
28 Gigabit Ethernet/IEEE 802.3 interface(s)
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0E:84:03:41:80
Motherboard assembly number : 73-9095-03
Power supply part number : 341-0045-01
Motherboard serial number : CAT0749098U
Power supply serial number : LIT074500WK
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C2970G-24TS-E
System serial number : CSG0750P05H
Top Assembly Part Number : 800-24261-01
Top Assembly Revision Number : B0
Switch Ports Model SW Version SW Image
* 1 28 WS-C2970G-24TS-E 12.1(14)EA1a C2970-I6L2-M
Press RETURN to get started!
Unexpected exception to CPU vector 2000, PC = 262E9C
-Traceback= 262E9C 262CC0 260308 25E564 25E72C 1CACD0
=== Flushing messages (02:01:28 UTC Mon Mar 1 1993) ===
Buffered messages:
00:01:21: %STACKMGR-6-SWITCH_ADDED: Switch 1 has been ADDED to the stack
00:01:23: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:01:26: %SYS-5-CONFIG_I: Configured from memory by console
00:01:26: %SYS-5-RESTART: System restarted --
fc1)
Queued messages:
00:01:128860398532: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console deb
ugging output.
fc1)
fc1)
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x001B9430 SRR1 = 0x00029210 SRR2 = 0x0028DB08 SRR3 = 0x00021000
ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x8C000000 DBSR = 0x01000000
CPU Register Context:
Vector = 0x00002000 PC = 0x00262E9C MSR = 0x00029210 CR = 0x53300000
LR = 0x00262E94 CTR = 0x002CD884 XER = 0xC0000040
R0 = 0x00262E94 R1 = 0x0156C868 R2 = 0x00000000 R3 = 0x0A0F0013
R4 = 0x011B76EC R5 = 0x00000001 R6 = 0x00000000 R7 = 0x00000000
R8 = 0x0A0F0008 R9 = 0x0A0F0000 R10 = 0x00000000 R11 = 0x011B63B8
R12 = 0x33300000 R13 = 0x00010000 R14 = 0x00000000 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000008
R24 = 0x012281E0 R25 = 0x00000240 R26 = 0x00000000 R27 = 0x00000002
R28 = 0x00000000 R29 = 0x0A0F0013 R30 = 0x0A0F0008 R31 = 0x07A1DA74
Stack trace:
PC = 0x00262E9C, SP = 0x0156C868
Frame 00: SP = 0x0156C898 PC = 0x00262E94
Frame 01: SP = 0x0156C8C0 PC = 0x00262CC0
Frame 02: SP = 0x0156C8E0 PC = 0x00260308
Frame 03: SP = 0x0156C900 PC = 0x0025E564
Frame 04: SP = 0x0156C928 PC = 0x0025E72C
Frame 05: SP = 0x00000000 PC = 0x001CACD0
C2970-S uptime is 1 minute, 33 seconds
bytes of memory.
Залез внутрь, заменил 5 дутых конденсаторов, но дефект не изменился. Какие рекомендации?
Если залить новый IOS, то как это сделать и как определить по названию файла, что есть в этой конфигурации?
Аватар пользователя ivp
Рекомендация одна (если все больное перепаяно) - перешить. Лучше программатором, ежели есть (или можно поковыряться хот-свапом). Версию прошивки взять последнюю. Примерно так.
ЗЫ: Там все очень просто определяется (касательно содержимого прошивки) - надо немного напрячь мозги, сопоставить даты и описания изменений.
- Ситчик веселенький есть?..
- Приезжайте, обхохочетесь!..
Аватар пользователя UAM
Собственно, не знаю, что может быть больное. Краем уха слышал, что у Cisco попадались бракованные SMD конденсаторы. Второй такой железки нет да и вряд-ли кто-то даст над ней издеваться.
Версию скачал, но в IOS не входит, а в загрузчике не нашел, как шиться.
Собственно, вопрос перешел уже в спортивную сферу. Поставили 3750.
Зы. Напряг, разобрался.
в 29ой вроде кондёров не много - заменить все электролиты, температурный режим из-за проца там нехороший.
Если была гроза, уже сколько раз попадался народ - думал проц... оказывался кварц, начинает врать, начинают врать таймеры - задачи в разных местах виснут, правда у вас более похоже на что-то другого характера.
Вам-бы спросить на nag.ru , там опытных cisco-вщиков практикующих достаточно много!
По очень настоятельной просьбе трудящихся - ориджин удалён и больше не появится. Гарантировать же отсутствие публикации статей со своей стороны не могу :P
Гроза была, но за несколько месяцев до выключения. Старых логов нет.
Тоже подумывал на прошивку.
Собственно, сейчас еще не актуально. Железка ждет списания и уничтожения. Вот после этого.... Если бловеры не утянут....
