Доброго времени суток.
Вообщем вопрос>>
Есть вот такой винт>
На наклейке:
FUJITSU
MODEL:MPG3409AH -EF ID: YTIM
PART NO: CA05762-B54200EF
SER NO: VL03T17032RK DATE: 2001-07
При включении компа раскручивается, но не видется в БИОСЕ!!!
Не видит: MHDD, HDDL, Fujitsu EXPLORER!!!
Видит только>>>
PCHDD.........
Log started...
Secondary address selected - base port set to:170
PCI BIOS version 2.10 found. Total : 2 PCI bus present
North Bridge found VID: 8086 DID: 7190
South Bridge found VID: 8086 DID: 7110
IDENTIFY_DEVICE ATA Rev 3.7b Dump:
00 B 1111111001011000
- General configuration bit-significant information:
15 0=ATA device / 1=ATAPI device
[14-8] Obsolete
7 1=removable media device
6 1=not removable controller and/or device
[5:1] Obsolete
0 Reserved
01 D 65112 - Number of logical cylinder
02 H FE58 - Reserved
03 D 65112 - Number of logical heads
04 H FE58 - Obsolete
05 H FE58 - Obsolete
06 D 65112 - Number of logical sectors per logical track
07 H FE58 - Vendor specific
08 H FE58 - Vendor specific
09 H FE58 - Vendor specific
0A S _X_X_X_X_X_X_X_X_X_X_
- Serial number (20 ASCII characters)
14 H FE58 - Obsolete
15 H FE58 - Obsolete
16 D 65112 - Number of vendor specific bytes available on READ/WRITE LONG
17 S _X_X_X_X_
- Firmware revision (8 ASCII characters)
1B S _X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_X_
- Model number (40 ASCII characters)
2F H FE58 - [15:8 ] Vendor specific
[7:0] 00h Reserved, 01h-ffh Maximum number of sectors that
can be transferred per interrupt on READ/WRITE MULTIPLE
commands
30 H FE58 - Reserved
31 B 1111111001011000
- Capabilities
[15:14] Reserved
13 1=Standby timer values as specified in this standard
are supported
0=Standby timer values are vendor specific
12 Reserved (for advanced transfer mode)
11 1=IORDY supported / 0=IORDY may be supported
10 1=IORDY can be disabled
9 Obsolete
8 Obsolete
[7:0] Vendor specific
32 H FE58 - Reserved
Отсюда понял что сбиты модули: 0A S, 17 S, 1B S !!!
VICTORIA FUJITSU (Простая тоже винт не видит!!!)
Init drive...... OK
ПАСПОРТ!!! почемуто не отдает модель и FirmWare (Ну наверно из-за битых модулей)
Model: X X X X X X X X X X X X X X X X X X X X ;
f/w: X X X X
S/N: X X X X X X X X X X;
LBAs: 156764504
LBA size: 76545 Mb; CHS: 2392/2392/2392/253028 Mb----это тоже не верно винт же 40Г
SMART: Not supported
Support: CHS,DMA(MWDMA2,UDMA6),APM,SMS
Security: Not supported.
Чтение модулей из служебной зоны.
Список поддерживаемых моделей:
1. MPG_AT #1. TAU (r/o)
2. MPG_AH #2. MHK_AT
3. MPF_AH #3. MHM_AT
4. MPF_AT #4. MHN_AT
5. MPE_AT #5. MHR_AT
6. MPE_AE #6. MHS_AT
7. MPD_AT #7. MHT_AT
8. MPC_AT #8. MHH_AT
9. MPB_AT #9. Reserved
0. UNIVERSAL #0. Mod 20h
_ Set valid mode...... OK
_ Read CP_1........ OK----ЗДЕСЬ ЗАВИСАЕТ!!!
RECOVERY TOOL 2.02А
ВИСНЕТ НА.........
NOW LOADING
PLEASE WAIT A FEW MINUTES
Пожалуйста подскажите что можно сделать! если залить новые модули, то где их брать???
Заранее благодарен!!!
У этого винта неисправен интерфейс.
Ведущий инженер техцентра "Виктория", Минск.
To Ruterian
А как его исправить?
С УВАЖЕНИЕМ
у которого? который в кернеле к блинам доступа не делает?
п.с. Сергей, я и не знал что ты на этом форуме бываешь....
электричество - это наука о контактах!
с уважением. Пьяный Мастер.
Кажись цирик не причем!!! если посмотреть на отчет PCHDD, то ясно видно, что сбиты модули отвечающие за отдачу модели диска, его серийника, и фирмвари !?
Если просто перешить ети модули мож заработает, иль не стоит, ето както по другому лечится???
С УВАЖЕНИЕМ
project857.narod.ru/topic/hard.htm --Ссылка на полное восстановление Fujiков с картинками и даже видео!!!
И еще много интересного!!!
С УВАЖЕНИЕМ
А отчего тогда модули слетели?
Если не контроллер, который посчти весь в этой БИС, то только ручки шаловливые...
Заработает. Если дохлый контроллер при записи не угробит чего ещё... А переписывать модули надо в общем случае с самого старшего по номеру неисправного модуля и по одному, проверяя получившийся результат.
Народ самое интересное>>> не могу считать модули, и узнать через PCHDD какие сбиты!!! как тогда шить новые? ааааааааааааа
С УВАЖЕНИЕМ
IMHO, ва дали все для старта - project857.narod.ru/topic/hard.htm
мало? вот еще - hardw.net/node/
а еще есть гугль, и если в строке поиска набрать ремонт фджей мпг, ой сколько интересного вылезет![wink](http://bios.rom.by/img/smiles/icon_wink.gif)
Электроника - наука о контактах. Все неисправности в ней
делятся на 2 категории или есть контакт там, где его быть не должно
или нет контак
To FRU Number
так я его полностью уже посмотрел все что мона, если б была такая трабла как часто у них бывает я б уже давно его восстановил!
Да кстати инфы я много про него прочитал, и везде пишут по разному!!!
С УВАЖЕНИЕМ
