Hi.
I'm using Lemonzest August 2003 BIOS for PCChips M810L. I'm able to set synchronous host/dram at 100 MHz but at 133MHz everything locks up after I setup the BIOS and reboot the system. Is there a way to fix it up?
Furthermore, does anybody know where to find the SiS 630S or 730S datasheets?
Here are some dumps by WPCREDIT:
Sync enable @ 100 MHz
![](http://img144.imageshack.us/img144/4271/configsync100si0.png)
Sync disable @ 100 MHz
![](http://img124.imageshack.us/img124/3606/confignosync100tr5.png)
Sync disable @ 133 MHz
![](http://img124.imageshack.us/img124/2784/confignosync133sg5.png)
Register 51h is altered by this option, and when I enter into Windows and play with this register everything locks up.
Looks like this setting is being used for setting the FSB:RAM ratio. It can't be changed on the fly.
What's the processor? Can suggest changing its FSB. Does the motherboard have jumpers to set 133MHz FSB?
Вместе мы - www.ROM.by!
My CPU is an Athlon XP 1800+. Mobo is jumperless.
And at BIOS defaults the FSB is 133? And what is the memory's frequency?
Bios defaults at 100. My RAM is PC133 CAS2
