From the fact that available - D101GGC
According to the specs, the boards are the same:
• ATI Radeon * Xpress 200 Northbridge
• ATI IXP 450 Southbridge
• 4 Mbit Firmware Hub (FWH)
• SMSC SCH5017
I think if you flash programmer for its BIOS, you may be able to run the BOOT-block and fill in their native firmware. I practice so do not try. downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
Download EFI_Unpacker rom.by/files/EFI_unpacker_0_10a.zip
Run
EFI_unpacker.exe GC1087.bio
Take
file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd
Make BIN
many FFs + file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd at end (total file size == size of flash chip).
Flash this BIN.
Run MB in recovery mode and let it try to flash GC1087.bio .
You have flash chip --> read marking --> size of flash chip --> create file (size of file == size of flash chip - size of file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd), which contains 0xFF (by means of WinHex, for example).
could someone provide me the bios in bin format
or kindly help me to convert the .bio file to bin format
• SMSC SCH5017
downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Probably need a PCI-video card
P.S. Обратный перевод тем же гуглом - просто вынос мозга
...ложки нет
das711
Thank you I will try that
I have tried by copying D101GGC bios. Result is no display with Ram Beep
bios Recovery didnt start from boot block
is it possible to edit .bio and make it to .bin format
Run
Take
Make BIN
Flash this BIN.
А кому счас легко...
thanks for the support
can you give me little more briefly
i have downloaded efi-unpacker
extracted the "file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd "
how to make bin can you help me on this
copy /b filename__FF + file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd filename_bin
filename_bin - binary image.
Rename
file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd to bootblock.bin for simplicity.
Run attached fillfile.exe as
fillfile.exe a.bin N 255, where N = size of flash chip MINUS size of bootblock.bin (dec number)
Make BIN
copy /b a.bin+bootblock.bin TESTBIOS.BIN
Test size of TESTBIOS.BIN - must be equal size of flash chip.
Flash testbios.bin and run in recovery mode.
