Пытался пропатчить биос в плате GA-8I945GZME-RH, в надежде, что удастся включить поддержку процессора Dual core E5300.
BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required! Found 4Mbit Award BIOS! Attention! - found Gigabyte-BIOS! Can`t found unpak_sub! 1. New CPU Support : not found. 2. P3-detect error : not found. 3. New Koeffs Support : not found. 4. 32Gb-problem : not found. 5. Some HDD detect-problem : not found. 6. "MB"/"GB" string search : is not needed to be fixed. 9. Error display Freq>999MHz : not found. 10.Error display Koefs>9.5x : not found. 11.New Stepping Support : is not needed to be fixed. 12.Tualatin L2-init error : not found. 13.New Freq in Setup open : not found. 14.Set "Y" as default on exit: not found. UDMA66/100/133 on UDMA33_only_MB patch: not found. Tweak options addinng: CBROM V2.07 (C)Award Software 2000 All Rights Reserved. CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding modul.tmp 17.9% CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding start.tmp 87.5% CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding tweak.tmp 36.0% CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding cpucode.bin 55.9% if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by (c)2006 Angel07, www.cgi-scripts.info
Вопрос: в принципе можно ли этого добиться, или я зря время трачу?
В сторону bootblock'а IMHO
