У меня есть CISCO 350.
Его не видят в радио. Статус мигает езернет тоже, а радио нет.
! CONFIGURATION of Cisco WGB350 V8.85 WGB350_4f6b08 = configuration radio ssid "tsunami" configuration radio rates 1_11 configuration radio basic_rates 1 configuration radio world off configuration radio i80211 rts 2048 configuration radio i80211 Privacy encryption off configuration radio i80211 Privacy auth open configuration radio extended parentid any configuration radio extended parent_timeout off configuration radio extended count_retry 64 configuration radio extended refresh 100 configuration radio extended diversity on configuration radio extended power full configuration radio extended stationary off configuration radio extended fragment 2048 configuration security mode off configuration security username "" configuration ethernet active on configuration ethernet transparent off configuration ethernet remove all configuration ethernet staletime 700 configuration ethernet keep off configuration identity bootp_DHCP off configuration identity name "WGB350_4f6b08" configuration identity class "WGB350" configuration identity inaddr 192.168.200.001 configuration identity inmask 255.255.255.000 configuration identity routing delete all configuration identity dns1 000.000.000.000 configuration identity dns2 000.000.000.000 configuration identity domain "" configuration identity location "" configuration identity contact "" configuration console delete all configuration console communities remote off configuration console type ansi configuration console linemode on configuration time time_server 000.000.000.000 configuration time sntp_server 000.000.000.000 configuration time offset 0 configuration time dst off configuration pspf off statistics display_time 10 association niddisp numeric filter multicast default forward filter multicast remove all filter node ethdst forward filter node remove all filter protocols default off filter protocols unicast off filter protocols remove all filter direction both diagnostics load ftp dest 000.000.000.000 diagnostics load ftp username "" diagnostics load ftp filename "" diagnostics load distribute type firmware diagnostics load distribute control newer diagnostics load distribute remove all logs printlevel severe logs loglevel all logs ledlevel error/severe logs bnodelog off logs snmp trapdest none logs snmp trapcomm "public" logs snmp loglevel off logs snmp authtrap off logs syslog 000.000.000.000 logs syslevel error/severe logs facility 16 logs rcvsyslog on
Я уже нифига не помню как руляться циски. тем более 350ые
но меня смутила вот эта строчка :
поробуй её убить.
See you later alligator....
Попробовал перенастроить:
Его пока не слышно.
- рекомендации лучших цисководов.
сбрось в дефот и настрой по новой
