Патчер ничего не находит, затем cbrom ругается на нехватку места. Полностью лог (попорченный, видимо cbrom):
Z:\1>BP.EXE BACKUP.BeN BIOS Patcher ver. 4 23. Attention! Advancet qualification is required! o Found 1Mbit BIOSn 1. New CPU Supeort : not found. 2. P3-detect vrror : not found. 3. New Koeffa Support : not found. 4. 32Gb-prohlem : not found. 4. 32Gb-problem : not found. 5. Some HDD detect-problem : not found. 6. "MB"/"GB" string search : not found. 9. Error display Freq>999MHz : not found. 10.Error display Koefs>9.5x : not found. 11.New Stepping Support : Warning! Not found "genu"! 12.Tualatin L2-init error : not found. 13.New Freq in Setup open : not found. CBROM V2.07 (C)Award Software 2000 All Rights Reserved. CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding modul.tmp 13.5% backup.bin have not enough space for adding ROM. (Over 01D9h bytes) CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding start.tmp 87.5% backup.bin have not enough space for adding ROM. (Over 01D9h bytes) CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding cpucode.bin .... 55.9% backup.bin have not enough space for adding ROM. (Over 01D9h bytes) if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2003 apple_rom, www.ROM.by Z:\1>
Вывод cbrom /d:
Z:\1>CBROM.EXE BACKUP1.BIN /D CBROM V2.07 (C)Award Software 2000 All Rights Reserved. ******** BACKUP1.BIN BIOS component ******** No. Item-Name Original-Size Compressed-Size Original-File-Name ================================================================================ 0. System BIOS FFFFFFFFh(-0.00K)10000h(64.00K) c►↑3SЕ`_Xf╠J╚Уa╥ИЄ╓╞Йt╙М╙Нa╙ н.м3Hмх▒Yд↕╣TБОm[╒╛∙╪ Total compress code space = 10000h(192.00K) Total compressed code size = 10000h(64.00K) Remain compress code space = 00000h(0.00K) ** Micro Code Information ** Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID ------------------+--------------------+--------------------+-------------------
Файл исходной прошивки я выложил по адресу alexim.homedns.org/romby/BACKUP1.BIN
А не могли бы Вы привести лог CBROM /D или BP /E. Хочется посмотреть что внутри у БИОСа, что так мало места...
ну, могу сказать, что т.к. BP завязан на CBROM, то "кривой" патчинг понятен... Странно, что CBROM не понимает формата БИОСа. Это точно Авард?
А сорри. :oops: Уже увидел
тоже неудивительно. Патчер тоже не понимает тип БИОСа....
Да, и линк на прошивку тоже не помешал бы....
PS: тут похоже нашел БИОСы для этой мамы (точнее, трех мам):
amptron.com/BIOS/8600C-050599.ZIP
amptron.com/BIOS/8600B-050599.ZIP
amptron.com/BIOS/8600A-012399.ZIP
Только они нормально патчатся и открываются cbrom'ом на ура
Аццкий ромбовод {:€
Файл выложил. Он слит унифлэшем с самой матери. А дальше интересно: в матери точно один из этих трех - у меня они все есть. Точнее 8600A-012399.ZIP, поскольку у меня PM8600A. А еще точнее - он не совпадает с моим бэкапом. Вот здесь наверное порылась собака.
И еще интереснее: патченный 8600A-012399 не щьется - ошибка размером с первую половину. Отшил обратно слитый образ.
1. Sempron 2800+, ASUS A7V880
2. Athlon XP 2200+, ABIT KT7A 1.0
3. PIII-533, Aopen AX6BC
4. Athlon 1200/100, ECS K7VMA (сдохла)
5. PIII-500, Asus P2L97
Gobzo
Сколько раз говорили, что не надо патчить БИОС из флеша...
Вот и в Вашем случае дампается БИОС криво, хотя во флешке он скорее всего нормальный, т.к. комп грузится.
Забавно, но ровно первая половина БИОСа слита неправильно. Либо баг юнифлеша, либо какая-то железная багофича...
Аццкий ромбовод {:€
Неправдочка Ваша!
А если серьезно, то как тогда возможно, что этот криво слитый дамп прекрасно заливается обратно и работает?
И почему, интересно, не зашивается патченный оригинальный биос? Я заливал в эту маму оригинальный тем же самым унифлэшем.
О, придумал! Надо заменить флешку для начала и попробовать опять.
Это нездоровые ампротоновские чипсобиосы. Не совсем стандартные (или правильнее - писанные, скорей всего, в пятницу вечером). Хотя часто легко приводимые в сибиромосъедобный вид.
А сделать чо-нибудь можно? Я патчил чтобы поставить туда Embedded P-MMX 266 и димы поболее
Вообще, непонятная мать... Горячая замена на ней не проходит, пробовал несколько флэшек и ни одна не опознается, вставляю обратно родную - опознается.
Видимо память мне изменила и я на самом деле не прошивал в нее ничего. Прошивка в маме не совпадает и близко с прошивкой из архива - вся первая половина пустая.
