Здравствуйте! Мой винчестер Seagate ST3000DM001 не определяется БИОС. Плата контроллера 100664987 REV A. FW: CC4C.
Диск раскручивается и слышно звук щелканья БМГ yadi.sk/d/GVbTzZ48rzoNW без терминала.
В терминале отвечает:
Boot 0x40M
Spin Up
TCC-0018[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0018
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
(DOS) Requesting File Save
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 00000000
[RSRS] 0000
ProcessRWError -Read- at LBA 0000000000000000 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000000!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Reconstruction: EXCEPTION: Error in Header
Reconstruction: EXCEPTION: Error in first Header disc sector
ReadFooters (Backwards): Segment 0000 StartLBA 00000000 Starting Footer LBA 000
00630
SeqNum 00000001
ProcessRWError -Read- at LBA 00000000000000C6 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000000C6!
Footer Status = 0000
ProcessRWError -Read- at LBA 00000000000000BD Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000000BD!
ProcessRWError -Read- at LBA 00000000000000B4 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000000B4!
ProcessRWError -Read- at LBA 00000000000000AB Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000000AB!
ProcessRWError -Read- at LBA 00000000000000A2 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000000A2!
ProcessRWError -Read- at LBA 0000000000000099 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000099!
ProcessRWError -Read- at LBA 0000000000000090 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000090!
ProcessRWError -Read- at LBA 0000000000000087 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000087!
ProcessRWError -Read- at LBA 000000000000007E Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000000007E!
ProcessRWError -Read- at LBA 0000000000000075 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000075!
ProcessRWError -Read- at LBA 000000000000006C Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000000006C!
ProcessRWError -Read- at LBA 0000000000000063 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000063!
ProcessRWError -Read- at LBA 000000000000005A Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000000005A!
ProcessRWError -Read- at LBA 0000000000000051 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000051!
ProcessRWError -Read- at LBA 0000000000000048 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000048!
ProcessRWError -Read- at LBA 000000000000003F Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000000003F!
ProcessRWError -Read- at LBA 0000000000000036 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000036!
ProcessRWError -Read- at LBA 000000000000002D Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000000002D!
ProcessRWError -Read- at LBA 0000000000000024 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000024!
ProcessRWError -Read- at LBA 000000000000001B Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000000001B!
ProcessRWError -Read- at LBA 0000000000000012 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000012!
ProcessRWError -Read- at LBA 0000000000000009 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000000009!
Reconstruction: EXCEPTION: Error in Header and ALL Footers.
Continuing after error
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001A
LED:00000047 FAddr:FFFFFFFE
и далее много повтор...
Это наверно медиа кеш отваливается, далее замкнул вывод 16 и 18 после Trans и водил команды в терминале:
Boot 0x40M
Spin Up
TCC-0029[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
Spin Up
TCC-0029
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Factory Init
MCInitialize: Start: Buffer Words VBM: 00000210
ClearMC: Start Full Media Cache size in host blks 00432380..S23(01).S21(01)..
ClearMC: Completed, Last LBA 00432380
MCInitialize: MC Cleared
MCInitialize: MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS]
MCInitialize: Init complete:
MCMainPOR: MCTStateFlags 00000022 MCStateFlags 00000041
MCMainPOR: Feature Enabled...
(DOS) FWR Done
(DOS) File Save
PowerState = IDLE1
PowerState = IDLE2
APM disabled by SPort
ASCII Diag mode
F3 T>/C
F3 C>U2
HighPowerMode
TCC-0029Status 0001 Req 0002
[MCMTWS]
Writing LBAs 0 through 1818
WARNING: Drive MC Area has been modified by serial port.
MC area must be re-initialized to ensure MC control data is valid
DO NOT SHIP WITHOUT FIRST RE-INITIALIZE MC AREA!
S23(01)S23(01)S23(01)Write complete
MC Area is re-initialized.
F3 C>/T
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 13.543 secs
F3 2>U
Spin Up Complete
Elapsed Time 8.602 secs
F3 2>
ASCII Diag mode
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>
ASCII Diag mode
F3 T>i4,1,22
F3 T>
ASCII Diag mode
F3 T>m0,2,2,0,0,0,0,22
Max Wr Retries = 00, Max Rd Retries = 00, Max Iterations = 00, Max Certify Rewr
ite Retries = 0000
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 13.552 secs
F3 2>
Подключил САТА тоже не определяется БИОС.
Что делать?
На днях тоже самое было,почистил всю площадку ластиком,так же все пятаки.После хорошей чистки он удачно стартанул.
Первоначально цель какая была? Выдернуть информацию или восстановить работоспособность?
revcrew8, я уже чистил и все гладко, как золото.
Но все равно не определяется.
slgor, выдернуть информацию и можно стереть. Мне не жалко.
Попробуй после того как попадаешь в терминал сразу пиши
F3 T>m0,2,2,,,,,22
F3 T>/1
F3 1>N1
Он должен сообщить об успешной очистке смарта. Дергаем питание и запускаем. И это... почему то после этого после подачи питания он начинает опознаваться ~ через 30 секунд. А потом норм
