Uniflash 2.00.SPI.RC01 - Рождественская версия Uniflash в статусе релиз-кандидата. Уже не только читает, но и шьёт-стирает. Пока лишь верно для ICH7 и Macronix. C проверкой-откаткой будем релизиться и после постепенно увеличивать список поддерживаемых южников и флешек.
Перешивал Uniflash 2.00.SPI.RC03 на плате ASUS P5GC-MX/1333 для ASUS P5KPL-AM SE через интерактивный режим, ничего не получилось.Что можете посоветовать. Предоставляю LOG :
22:36:49.08: UniFlash v2.00.SPI.RC03 started: C:\UNIF2RC3.EXE /LOG
22:36:49.08: Flat Real Mode initialized
22:36:49.13: BIOS CNTL=00000001
22:36:49.13: SpiBar base address=FED1C000
22:36:49.13: BootBIOSDest=04
22:36:49.13: SPIS=0004
22:36:49.13: SPIC=4040
22:36:49.13: SPIA=00301400
22:36:49.19: SPID0=0000000000143013
22:36:49.24: SPID1=0000000000000000
22:36:49.24: SPID2=0000000000000000
22:36:49.24: SPID3=0000000000000000
22:36:49.30: SPID4=0000000000000000
22:36:49.30: SPID5=0000000000000000
22:36:49.30: SPID6=0000000000000000
22:36:49.30: SPID7=0000000000000000
22:36:49.30: BBAR=00000000
22:36:49.30: PREOP=0006
22:36:49.35: OPTYPE=463B
22:36:49.35: OPMENU=C79F01AB05D80302
22:36:49.35: PBR0=00000000
22:36:49.35: PBR1=00000000
22:36:49.35: PBR2=00000000
22:36:49.35: Programming OPCODES...
22:36:49.35: Write PREOP=0006
22:36:49.41: Write OPTYPE=463B
22:36:49.41: Write OPMENU[0]=05D80302
22:36:49.41: Write OPMENU[1]=C79F01AB
22:36:49.41: done
22:36:49.41: SPI Read Conf in 00000001 is:
22:36:49.41: prefetching=00, caching=00
22:36:49.52: Chipset detected: i945G/GZ/P/PL + i82801GB/R ICH7(R)
22:36:49.52: CMOS size detected: 256b
22:36:49.52: Found DMI 2.4 board info: ASUSTeK Computer INC. P5GC-MX/1333 Rev x.xx
22:36:49.52: Intel 9xx method: reg $DC = 00000001
22:36:49.57: Intel 9xx method: reg $DC changed to 00000001
22:36:49.57: Intel 9xx method: reg $D8 = 000080C0
22:36:49.57: Intel 9xx method: reg $D8 changed to 0000FFCF
22:36:49.57: System ROM selected
22:36:49.57: run_opcode(read): op=9F addr=00000000 readcnt=03
22:36:49.57: Enter ich7_run_opcode: opcode=9F offset=00000000 count=03
22:36:49.63: Write SPIC=4262
22:36:49.63: Read result SPID=001430EF
22:36:49.63: Found spi flash chip W25X80
22:36:49.68: Allocating memory block 00800000
22:36:49.68: Allocating memory block 00001080
22:36:49.68: Flash ROM chip detected: Winbond W25X80
22:36:49.74: Flash ROM ID: EF00,3014
22:36:49.74: UniFlash running in interactive mode
22:37:26.81: Exiting UniFlash...
22:37:26.87: Intel 9xx method: restoring reg $DC from 00000001
22:37:26.87: Intel 9xx method: restoring reg $D8 from 0000FFCF
22:37:26.87: Turning off logging, shutting down to real mode
Взять flashrom.
А кому счас легко...
Никогда не пользовался flashrom,как я понял, он прошивает с работающей ОС, мне нечем запустить ASUS P5KPL-AM SE.
Да я как-то не вижу особой разницы между uniflash и flashrom (в виде DOS-порта).
P.S. Да, и закажите у китайцев CH341A. За цену пары банок пива решается куча такого плана вопросов.
Особенно с ASUS c их любовью к DIP и "кроваткам".
