Добрый день, внезапно обнаружил что уже достаточно давно живу на деградированом массиве.
Данные виновника следуют ниже.
Я совершенно потерял квалификацию и не могу интерпретировать ошибки.
Тело уже сдавать в морг, либо с ним еще что-то можно сделать?
decs:~# smartctl -a /dev/hda
smartctl version 5.38 [i686-pc-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (3585) seconds.
capabilities: (0x1b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 60) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 060 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0007 112 112 024 Pre-fail Always - 269 (Average 262)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 1363
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 020 Pre-fail Offline - 0
9 Power_On_Hours 0x0012 097 097 000 Old_age Always - 21207
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1352
192 Power-Off_Retract_Count 0x0032 099 099 050 Old_age Always - 2312
193 Load_Cycle_Count 0x0012 099 099 050 Old_age Always - 2312
194 Temperature_Celsius 0x0002 152 152 000 Old_age Always - 36 (Lifetime Min/Max 15/52)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 192 192 000 Old_age Always - 962
SMART Error Log Version: 1
ATA Error Count: 16 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 16 occurred at disk power-on lifetime: 21205 hours (883 days + 13 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 51 00 ea ec be e6 Error: ICRC, ABRT at LBA = 0x06beecea = 113175786
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
35 00 f0 fb e8 be e0 00 06:21:27.900 WRITE DMA EXT
10 00 3f 00 00 00 e0 00 06:21:27.900 RECALIBRATE [OBS-4]
35 00 f0 fb e8 be e0 00 06:21:27.800 WRITE DMA EXT
Error 15 occurred at disk power-on lifetime: 21205 hours (883 days + 13 hours)
35 00 f8 f3 e8 be e0 00 06:21:27.800 WRITE DMA EXT
Error 14 occurred at disk power-on lifetime: 21205 hours (883 days + 13 hours)
ef 03 40 ea ec be e0 04 06:21:27.700 SET FEATURES [Set transfer mode]
ef 03 40 ea ec be e0 02 06:21:27.700 SET FEATURES [Set transfer mode]
Error 13 occurred at disk power-on lifetime: 21205 hours (883 days + 13 hours)
35 00 f8 f3 e8 be e0 00 06:21:27.700 WRITE DMA EXT
Error 12 occurred at disk power-on lifetime: 21205 hours (883 days + 13 hours)
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 21207 -
# 2 Extended offline Completed without error 00% 8214 -
# 3 Extended offline Completed without error 00% 3836 -
Device does not support Selective Self Tests/Logging
# 1 Extended offline Completed without error 00% 8214 -
# 2 Extended offline Completed without error 00% 3836 -
Я бы, раз уж, он в массиве числится как вышедший из игры, подключил его к компу индивидуально и прогнал бы по полной программе DFT. Возможно даже начал бы с того, что сделал бы ему Full Erase тем же DFT или Викторией, а после этого уже DFT Long Test c оргвыводами по результатам. Вообще-то у меня эта модель какими-то с глюками не ассоциируется, но тут лучше бы послушать, что скажут ремонтники, т.к. моя статистика не претендует на сколько-то приличную репрезентативность (м.б. десяток, много два, накопителей этой серии, с которыми я имел дело и, соответственно, могу отслеживать их состояние здоровья)
