очень нужен биос для этой материнки
albatron.com.tw/English/Service/bios_index.asp?keywords=kx400&Submit=S...
Аццкий ромбовод {:€ Я пока не волшебник - я только учусь! :-P
сайт не отвечает...
Сайт отвечает самым волшебным образом:
KX400-8XV (V3.0) 0.23 MB R3.00 2003/11/21 Initial Release Version KX400-8XV (V3.0) 0.23 MB R3.00a(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version) KX400-8XV (V3.0) 0.23 MB R3.01 2004/9/24 Supports Sempron CPU KX400-8XV Pro (V3.0) 0.23 MB R3.00 2003/11/21 Initial Release Version KX400-8XV Pro (V3.0) 0.21 MB R1.02c(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version) KX400-8XV Pro (V3.0) 0.23 MB R3.00a(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version) KX400-8XV Pro (V3.0) 0.23 MB R3.01 2004/9/24 Supports Sempron CPU KX400-8XV (V2.0) 0.22 MB R2.03 2003/9/3 Initial Release Version ( Support KX400-8XV / Pro Version 2.0 mainboard only) KX400-8XV (V2.0) 0.22 MB R2.05 2003/10/23 1.Fixed hang C1 if set CPU ratio and FSB(100,133,166,200) at the same time. KX400-8XV (V2.0) 0.22 MB R2.05a(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version) KX400-8XV Pro (V2.0) 0.22 MB R2.03 2003/9/3 Initial Release Version ( Support KX400-8XV / Pro Version 2.0 mainboard only) KX400-8XV Pro (V2.0) 0.22 MB R2.05 2003/10/23 1.Fixed hang C1 if set CPU ratio and FSB(100,133,166,200) at the same time. KX400-8XV Pro (V2.0) 0.22 MB R2.05a(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version) KX400-8XV Pro 0.21 MB R1.01 2003/8/27 Initial Release KX400-8XV Pro 0.21 MB R1.01a( Beta ) 2003/10/2 Beta Version 1. Support Barton 3000+ ( FSB 333) CPU. KX400-8XV Pro 0.21 MB R1.01b(Beta) 2003/10/2 Beta Version 1.support new Duron FSB = 266 (Applebred) CPU. KX400-8XV Pro 0.22MB R1.02c (Beta) 2004/11/4 Support AMD Sempron CPU KX400-8X 0.19 MB R1.01 2003/8/27 Initial Release KX400-8X 0.18 MB R1.01e( Beta ) 2003/10/2 Beta Version 1. support 2600+ ( FSB333 MHz) CPU KX400-8X 0.18 MB R1.03 2003/10/2 1. Support Athlon™XP 2600+ ( FSB 333) CPU. 2. Support Barton 2800+ ( FSB 333) CPU. 3. Fixed low speed FAN can't be detected. KX400-8X 0.18 MB R1.05 2003/10/2 1. Improve ATI9700Pro stability. 2. Support Barton 3000+ ( FSB 333) CPU. KX400-8X 0.18 MB R1.05b(Beta) 2003/10/2 Beta Version 1. support new Duron FSB = 266 (Applebred) CPU. KX400-8X 0.18 MB R1.05c (Beta) 2004/11/4 Support AMD Sempron CPU KX400-8XV 0.21 MB R1.01 2003/8/27 Initial Release KX400-8XV 0.21 MB R1.01a( Beta ) 2003/10/2 Beta Version 1. Support Barton 3000+ ( FSB 333) CPU. KX400-8XV 0.21 MB R1.01b(Beta) 2003/10/2 Beta Version 1.support new Duron FSB = 266 (Applebred) CPU. KX400-8XV 0.21 MB R1.02c(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version) KX400-8XV 0.22MB R1.02c (Beta) 2004/11/4 Support AMD Sempron CPU KX400+ 0.19MB R1.01 2003/10/2 Initial Release KX400+ 0.19MB R1.02 2003/10/3 1. Fixed system won't boot if held down "Insert" key before power on. 2. Fixed 98SE S3 resume fail if connect CDROM and enable CDROM DMA mode. 3.Added new item "Power Button Up" for Disable power button function if select PS2 keyboard wakeup.< KX400+ 0.19 MB R1.04 2003/10/2 1. Fixed audio will disappear after restarting the OS 2. Fix USB2.0 device + USB hub cause USB2.0 device speed down to 1.1 3. Fixed "DDR:CPU Ratio" display error when FSB = 166( JP2 = 34)(only 2.00X) 4. Fixed "USB Controller" itemvalue display er KX400+ 0.19 MB R1.04f(Beta) 2003/10/2 Beta Version 1. support Athlon™ XP 2600+ ( FSB333 MHz) CPU. KX400+ 0.19 MB R1.05 2003/10/2 1. Support Athlon™ XP 2600+ (FSB 333) CPU 2. Support Barton 2800+ (FSB 333) CPU 3. Fixed low speed FAN cannot be detected KX400+ 0.19 MB R1.06 2003/10/2 1. Support Barton 3000+ (FSB 333) CPU KX400+ 0.19 MB R1.06a(Beta) 2003/10/2 Beta Version 1. support new Duron FSB = 266 (Applebred) CPU. KX400+ 0.19 MB R106b(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version) KX400+ Pro 0.19MB R1.02 2003/10/2 Initial Release KX400+ Pro 0.19 MB R1.03A( Beta) 2003/10/2 Beta Version 1.Fix Dip switch clock to 166 DDR ratio X 2 2.Fix clock 166 overclock issue 3.Enhance performance. KX400+ Pro 0.19 MB R1.04 2003/10/2 1. Fixed audio will disappear after restarting the OS 2. Fix USB2.0 device + USB hub cause USB2.0 device speed down to 1.1 3. Fixed "DDR:CPU Ratio" display error when FSB = 166( JP2 = 34)(only 2.00X) 4. Fixed "USB Controller" itemvalue display er KX400+ Pro 0.19 MB R1.04f(Beta) 2003/10/2 Beta Version 1. support Athlon™ XP 2600+ ( FSB333 MHz) CPU. KX400+ Pro 0.19 MB R1.05 2003/10/2 1. Support Athlon™ XP 2600+ (FSB 333) CPU 2. Support Barton 2800+ (FSB 333) CPU 3. Fixed low speed FAN cannot be detected KX400+ Pro 0.19 MB R1.06 2003/10/2 1. Support Barton 3000+ (FSB 333) CPU KX400+ Pro 0.19 MB R1.06a(Beta) 2003/10/2 Beta Version 1. support new Duron FSB = 266 (Applebred) CPU. KX400+ Pro 0.19 MB R106b(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version) KX400+Pro-C 0.19 MB R1.00 2003/10/2 Initial Release KX400+Pro-C 0.19 MB R1.03A( Beta) 2003/10/2 Beta Version 1.Fix Dip switch clock to 166 DDR ratio X 2 2.Fix clock 166 overclock issue 3.Enhance performance. KX400+Pro-C 0.19 MB R1.04 2003/10/2 1. Fixed audio will disappear after restarting the OS 2. Fix USB2.0 device + USB hub cause USB2.0 device speed down to 1.1 3. Fixed "DDR:CPU Ratio" display error when FSB = 166( JP2 = 34)(only 2.00X) 4. Fixed "USB Controller" itemvalue display er KX400+Pro-C 0.19 MB R1.04f(Beta) 2003/10/2 Beta Version 1. support Athlon™ XP 2600+ ( FSB333 MHz) CPU. KX400+Pro-C 0.19 MB R1.05 2003/10/2 1. Support Athlon™ XP 2600+ (FSB 333) CPU 2. Support Barton 2800+ (FSB 333) CPU 3. Fixed low speed FAN cannot be detected KX400+Pro-C 0.19 MB R1.06 2003/10/2 1. Support Barton 3000+ (FSB 333) CPU KX400+Pro-C 0.19 MB R1.06a(Beta) 2003/10/2 Beta Version 1. support new Duron FSB = 266 (Applebred) CPU. KX400+Pro-C 0.19 MB R106b(Beta) 2004/8/30 1.Support Sempron CPU.(Beta Version)
Открытая книга: icbook.com.ua
icbook уже заработал
Аццкий ромбовод {:€
сайт не отвечает...
icbook![:)](http://bios.rom.by/img/smiles/icon_smile.gif)
уже заработал
