по ТОШИБА-м полезная инфа, как интерпритировать мигания индикаторов: Другими словами обратите внимание на мигания индикаторов и запишите их в виде: короткое мигание - К =0 (логическому 0) длинное мигание - Д=1 (логической 1) далее, например мои случай:
4 коротких мига + 5 длинный после 3 коротких ( короткие длительностью приблизительно пол секунды, с интервалом 1 сек, 5-й длительностью около 1 сек
...._... ...._... ...._... по кругу
читаем справа на лево:
00010000 00010000 00010000
00010000 = 10h= AC Adaptor output voltage is more than 16.5 V. итд.
коды смотрим по выдержкам из сервис мануала
необходимо учитывать тот факт что для разных моделей коды будут значить разное, ниже приведенные коды относятса к _данной_ серии буков.
DC IN Error code Meaning
10h - AC Adaptor output voltage is more than 16.5 V.
12h - Current from the DC power supply is more than the limit (6.05 A).
13h - Current from the DC power supply is more than the limit (0.5 A) when there is no load.
14h - Current sensing IC is not normal.
Main Battery Error code Meaning
21h - Main battery charge current is more than 6.05 A.
22h - Main battery discharge current is more than 0.5 A when there is no load.
23h - Main battery charge current is more than 3.1A when DC IN direct charge is off.
24h - Current sensing IC is not normal.
25h - Main battery charge current is more than 0.3A when the battery isn't being charged.
S3V output Error code Meaning
40h - S3V voltage is not more than 3.14V when the computer is powered on or off.
45h - S3V voltage is not more than 3.14V when the computer is supports CV and is booting up.
C5V output Error code Meaning
50h - C5V voltage is more than 6.00 V when the computer is powered on or off.
51h - C5V voltage is not more than 4.50 V when the computer is powered on.
52h - C5V voltage is not more than 4.50 V when the computer is booting up.
53h - C5V voltage is not normal when the computer is suspended.
54h - C5V voltage is not normal when the computer supports CV and is suspended.
55h - C5V voltage is not more than 4.50V when the computer supports CV and is booting up.
C3V output Error code Meaning
60h - C3V voltage is more than 3.96 V.
61h - C3V voltage is not more than 2.81 V when the computer is powered on.
62h - C3V voltage is not more than 2.81 V when the computer is booting up.
63h - C3V voltage is not normal when the computer is suspended.
64h - C3V voltage is not normal when the computer supports CV and is shut down.
65h - C3V voltage is not more than 2.81V when the computer supports CV and is booting up.
PPV output (PCU core voltage) Error code Meaning
70h - PPV voltage is more than 1.56V when the computer is powered on or off.
71h - PPV voltage is not more than 0.68V when the computer is powered on.
72h - PPV voltage is not more than 0.68V when the computer is booting up.
73h - PPV voltage is not less than 0.68V when the computer is powered off.
BGVSNS output Error code Meaning
80h - BGVSNS voltage is not more than 1.62V when the computer is on or off.
81h - BGVSNS voltage is not more than 1.02V when the computer is powered on.
82h - BGVSNS voltage is not more than 1.02V when the computer is booting up.
83h - BGVSNS voltage is not less than 1.02V when the computer is powered off.
84h - BGVSNS voltage is not more than 1.62V when the computer is suspended.
1R5-E1V output Error code Meaning
90h - 1R5-E1V voltage is more than 1.80V when the computer is powered on or off.
91h - 1R5-E1V voltage is not more than 1.275V when the computer is powered on.
92h - 1R5-E1V voltage is not more than 1.275V when the computer is booting up.
93h - 1R5-E1V voltage is not less than 1.275V when the computer is powered off.
94h - 1R5-E1V voltage is not more than 1.275V when the computer is suspended.
1R8-E1V output Error code Meaning
A0h - 1R8-E1V voltage is more than 2.16V when the computer is powered on or off.
A1h - 1R8-E1V voltage is not more than 1.53V when the computer is powered on.
A2h - 1R8-E1V voltage is not more than 1.53V when the computer is booting up.
A3h - 1R8-E1V voltage is not less than 1.53V when the computer is powered off.
A4h - 1R8-E1V voltage is not more than 1.53V when the computer is suspended.
2R5-SNS output Error code Meaning
B0h - 2R5-SNS voltage is more than 3.00V when the computer is powered on or off.
B1h - 2R5-SNS voltage is not more than 2.125V when the computer is powered on.
B2h - 2R5-SNS voltage is not more than 2.125V when the computer is booting up.
B3h - 2R5-SNS voltage is not less than 2.125V when the computer is powered off.
B4h - 2R5-SNS voltage is not more than 2.125V when the computer is suspended.
1R25-E1V output Error code Meaning
C0h - 1R25-E1V voltage is more than 1.50V when the computer is powered on or off.
C1h - 1R25-E1V voltage is not more than 1.063V when the computer is powered on.
C2h - 1R25-E1V voltage is not more than 1.063V when the computer is booting up.
C3h - 1R25-E1V voltage is not less than 1.063V when the computer is powered off.
C4h - 1R25-E1V voltage is not more than 1.063V when the computer is suspended.
2R5-E1V output Error code Meaning
D0h - 2R5-E1V voltage is more than 3.00V when the computer is powered on or off.
D1h - 2R5-E1V voltage is not more than 2.125V when the computer is powered on.
D2h - 2R5-E1V voltage is not more than 2.125V when the computer is booting up.
D3h - 2R5-E1V voltage is not less than 2.125V when the computer is powered off.
D4h - 2R5-E1V voltage is not more than 2.125V when the computer is suspended.
