I have new moment with this particular mobo: At first i had just POST C0(quick A8 and again C0).After overblowing socket I had FF. I took bottle of Acohol and use a great amount of it on socket it self. After 30 minutes I turn on mobo with CPU in it. FF again, but, when I press hardly on one edge of CPU cooler and took RESET I got C0-E1. After relesing cooler and RESET, again FF. Otval in it`s basic form! I blowed several times again and rising temperature from 350-385 grade celsius. Situacion the same. Can I use higher temperature then 400 grade? Or this socket is not posible to overblow and must bee replaced?
P.S. Question from first post is stial topical. Must I use large quantity of flux to solder and spend 5 cubics of alcohol and 2 hours to clean it or there is some simplier way?
