Found 2Mbit BIOS (4.5x)!
Attention! - found Gigabyte-BIOS!
Remove GA-blocking "+PCI" in BootBlockRemove GA-blocking "+PCI" in BootBlock
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support :> -> fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Add "+PCI"-menu in BIOS Setup.
Remove GA-blocking "+PCI" in BIOS SetupAdding timings-tweak.Adding "Turbo RAM"-
weak.
UDMA for "big"-HDD on UCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 29.9%
Adding start.tmp 87.5%
Adding cpucode.bin .... 55.9%
Warning! BootBlock was changed! Flashing BIOS only WITH BootBlock!
(c)2002-2003 apple_rom, www.ROM.by
Проверьте, все ли необходимые файлы для работы патчера лежат в его папке, и соблюдены ли остальные требования (поиском по ветке патчера найдете все)...
Да что Вы тут рыдаете, в конце-то концов, прекрасно он патчится:
weak.
