BIOS Patcher ver. 4.51.
Found 2Mbit BIOS (4.5x)!
Attention! - ASUS BIOS!
1. New CPU Support :for skip this step press "s" or any another key for continue...
-> fixed.
2. P3-detect error : not found.
3. New Koeffs Support :>for skip this step press "s" or any another key for continue... -> fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem :for skip this step press "s" or any another key for continue...M -> fixed.
6. "MB"/"GB" string search :for skip this step press "s" or any another key for continue...h -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support :for skip this step press "s" or any another key for continue...h -> fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit:for skip this step press "s" or any another key for continue...h -> fixed.
UDMA66/100/133 on UDMA33_only_MB patch: not found.
Tweak options addinng:
CBROM V2.05 (C)Award Software 1999 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.05 (C)Award Software 1999 All Rights Reserved.
Adding modul.tmp 28.7%
Adding tweak.tmp 69.5%
Adding cpucode.bin 50.7%
Warning! BootBlock was changed! Flashing BIOS only WITH BootBlock!
(c)2002-2003 apple_rom, www.ROM.by
Вот лог работы патчера
-> fixed.
вроде все нормально если судить по логу.
