I used bios patcher v6.00alpha15 and patched the BIOS image file. BP said that all modules were patched successfully. Than I flashed the patched image file to the BIOS with AMIflash. But the CPUs are still not recognized by the BIOS. I took the REALL.COD file, but there isn't a Microcode for the PIIOD in it. So I used the 1632-02.COD from All_Microcodes.zip and renamed it to REALL.COD and patched the BIOS again. Same thing... I hope I did it right.
I posted the problem to other forums. People there said, that they used AMIBCP for Windows, but this Version doesn't work with my BIOS image file. Than they used AMIBCP for DOS Version 7.xx ---> This version worked with my image file, but they don't find a microcode module in it.
Someone other said, that in the TYAN manual stands something about AMIBCP version 6.XX . Maybe I should use this one to patch, but nobody find this version in the web?!
Hi,
Any other idea?
Cheers
Markus
