maco, какую еще инфу надо? Я задал вопрос, послал фото. Если надо инфу о том как отключать POV на "IBMrev1:6", то надо тему в песочницу. А насчет прошивок BIOSа: имеет место смещения адресов которые феникс принимает за ошибки при открытии и пробовать открывать образ с конца. Резать BIOS IBM не рекомедую, т.к. можно обрезать вместе с ногами и фалос смотри " Updated by rak_dj, пн., 06/12/2010 - 06:06 >> 13 >> Написать автору". Есть такая штука как "TCPA" (кроме POV) Вот выдержка из стрингов BIOSа ".......till be able to enter
Setup using the F1 key. Error Startup Sequence: First Startup Device: Fourth Startup Device: Second Startup Device: Startup Sequence Select this option to
change the system
Startup Sequence. Startup Third Startup Device: Stay Off AssetID Antenna Installed Audio Support Fan 1 Fan 2 Select this option to
view a summary of the
system hardware
configuration. Dual Processor Enabled Ethernet Support Enabled SCSI Support Enabled Memory Bus Speed System Summary System Disabled Select whether to
enable or disable the
system board Ethernet
controller. System Board Ethernet: System Serial Number UUID Select this option to
view the system's
Universal Unique
Identification (UUID)
string. IBM TCPA Security Feature: This option allows you
to enable or disable
the IBM TCPA Security
feature. Chassis Intrusion Clear IBM TCPA Security Feature: This option is used to
clear encryption keys.
It will not be
possible to access
already-encrypted data
after these keys are
cleared. IBM TCPA Feature Setup This option allows you
to configure the IBM
TCPA Feature. Non Fatal Error IBM TCPA Reporting Options This option allows you
reporting options of
the IBM TCPA security
feature. Enabled
options will be
reported via PCR1 as
defined in the TCPA
specification. Legacy Fan Control: Selects the fan speed
mode.
Select "Quiet" to
reduce the amount of
system noise by
reducing fan speed.
This setting might
also cause the
processor speed to
be reduced.
Select "Normal" to
get the best processor
performance. System Time (HH:MM:SS): Fast Use this field to set
the speed at which the
keyboard places
characters on the
screen when you type.
The "Normal" keyboard
speed places characters
on the screen
at a rate of 10
characters-per-second.
The "Fast" keyboard
on the screen at a rate
of 30 characters-
per-second. Keyboard Speed: Option Keys Display Style: Controls the style of
prompts displayed on
the IBM POST Logo
screen when the system
is turned on.
Choosing "Normal" will
prompt for the Enter
key and display a menu.
Choosing "Legacy" will
prompt for F1, F11, or
F12. Select whether to
enable BIOS support
for USB devices (such
as a mouse or keyboard)
when the system is
started. USB devices
should work in the
operating system even
when this option is
disabled. USB Device Support: USB Setup.........." а она находится где-то в коце. Помощи себе я так и не дождался, но надеюсь то, что написано может кому-то пригодится ...
change the system
system hardware
view the system's
Universal Unique
It will not be
possible to access
feature. Enabled
options will be
defined in the TCPA
mode.
Select "Quiet" to
system noise by
reducing fan speed.
This setting might
also cause the
processor speed to
be reduced.
Select "Normal" to
keyboard places
characters on the
on the screen
at a rate of 10
The "Fast" keyboard
of 30 characters-
the IBM POST Logo
is turned on.
enable BIOS support
when the system is
should work in the
when this option is
