На ВХ ставят 133Мгц камни "на свой страх и риск". Чипсет НИКОГДА не поддерживал официально эту шину, но она "есть" на платах.Источник любительский , но все же :http://en.wikipedia.org/wiki/Intel_440BX
"And, unofficially, the 440BX could often be taken to 133 MHz FSB. Enthusiast motherboards, such as the Asus P3B-F and Abit BH6/BF6/BE6 series, were equipped with BIOS options to set the board to this unofficial speed. With a 133 MHz FSB, the 440BX could even match the later i815 chipset, which was designed to accommodate the final Tualatin-core Pentium III. Unfortunately, running a 440BX above 100 MHz FSB resulted in the AGP video card being forced to run on an overclocked AGP bus, as the 440BX only had "2/3" and "1/1" bus dividers. Some video cards were tolerant of this, such as various early NVIDIA GeForce cards, but more than a few were quite unstable with a 35% AGP overclock.
Still, the later i815 was considered the best Pentium III chipset because it offered a better feature set and very similar performance relative to the 440BX. Not only did the i815 support a proper "1/2" AGP divider for the 133 MHz FSB clock rate, AGP 4x, and Ultra DMA 100, but the later revisions also directly supported the Tualatin Pentium III."
Пробуйте. Гугл ?
Драйверы:а кроме русского есть, скажем американский ,немецкий и другие саиты Гигабайта и FTP вроде.
Но смысл , что искать ?
Пробуйте. Гугл ?
