Докладываю) На прошивке H/T CODE TJ29Z3FA.DN; B/I CODE
Докладываю) На прошивке H/T CODE TJ29Z3FA.DN; B/I CODE TJ29Z3BA.DN3; MAIN CODE Downsize Code TM31NM2.BIN, пытался 2 раза, форматировал СА, все до лампочки(((. H/T проходит усспешно. а бурн не в зуб ногой.
[Burn-In Result - 0863JXXXX]
Stop Condition - (4A)
Unknown Stop Condition
Last executed Command -
Download P60 code
Last executed Step - 75
Total Error Count - 0
Error List Pointer - 6700H
Last Error Log addr - ( 12, 0, 0)
Temp disk addr - ( 0, 0, 0)
Command List Ptr - 6038H
Current disk addr - ( 4, 0, 85)
Start, End cylinder - 24 ~ 86448
Used Burn-In Code - tk29z3aB
Burn-In Run Time - 04:50:48
bflag : 0100H opt_flag : 0908H
ecc_flag : 0001H cache_option : 0000H
maxsrty : 0000H maxwrsrty : 0000H
hys_val : 0000H ad_ofs : 0000H
p1_error : 0000H
оборвалось
189 00:00:00 04:50:48 [24] Set ECC/Retry Count ECC: OFF Retry: 3
190 00:00:00 04:50:48 [25] Set ECC Length ECC Length:24
191 00:00:00 04:50:48 [35] Set RCO Test Area ZnMskHi:0x00FF ZnMskLo:0xFFFF HdMsk:0x000F
192 00:00:00 04:50:48 [23] Set R/W channel Enable MNP
193 00:00:00 04:50:48 [82] Dummy Read
194 00:00:00 04:50:48 [92] RND BER Measurement ARG:0x0001 Read #:16 BER Crit:10
195 00:00:00 04:50:48 [23] Set R/W channel Disable MNP
196 00:00:00 04:50:48 [69] Servo CAL_SKTIME ARG:0x8400
197 00:00:00 04:50:48 [64] Interfere test
198 00:00:00 04:50:48 [64] Interfere test
199 00:00:00 04:50:48 [64] Interfere test
200 00:00:00 04:50:48 [34] FormatTemperatureRecord
201 00:00:00 04:50:48 [AF] Bias Shock Test
202 00:00:00 04:50:48 [1C] Parameter Monitor PASS #:15
203 00:00:00 04:50:48 [21] Set Offtrack 6%
204 00:00:00 04:50:48 [23] Set R/W channel MNP, Data:0x0000
205 00:00:00 04:50:48 [23] Set R/W channel Addr:0x0033 , Data:0x0002
206 00:00:00 04:50:48 [80] Read Track Forward LOOP #:1
207 00:00:00 04:50:48 [23] Set R/W channel Disable MNP
208 00:00:00 04:50:48 [23] Set R/W channel Addr:0x0033 , Data:0x0081
209 00:00:00 04:50:48 [21] Set Offtrack 0%
210 00:00:00 04:50:48 [24] Set ECC/Retry Count ECC: ON Retry: 31
211 00:00:00 04:50:48 [C2] Defect free & format Fail on R/W err:1
212 00:00:00 04:50:48 [11] OEM Data Collect ARG:0 RCNT:0 PCNT:0
213 00:00:00 04:50:48 [02] Execute Diagnostic
214 00:00:00 04:50:48 [02] Execute Diagnostic
215 00:00:00 04:50:48 [1F] End Of Test
На прошивке TJ31F.DN; DOWNSIZE BI TS31B.DN3; DOWNSIZE MAIN TV24M.BIN Вышла не подходящая мне модель SP0622N, на 60 га, и всё работало успешно, никаких ошибок, только вот средняя скорость доступа была не 56000, а 41000. Я ждал и надеялся на SP0812N.
Rezultaty.rar 4.89 КБ
SAMSUNG SP1213N. Как влить служебку потреково?
  • В 2х словах, если нужной инфы на WD-шке
  • Откуда это известно,что прошивка? Что такое прошивка? Зальёте служебку
  • Повторить процедуру рубки голов, но не выделять
  • Всем спасибо за советы, у меня осталось ещё
  • Всё!!)), я его победил, я наконец получил нормальную,
  • ram_gun Всё там подходит.Комплект подбирается по
