One more example: Asrock P4i65gv, AMIBIOS, Intel i865
BOOTBLK:56B1 ; =============== S U B R O U T I N E ======================================= BOOTBLK:56B1 BOOTBLK:56B1 BOOTBLK:56B1 SMBus_WriteBlock proc near ; CODE XREF: sub_F54A6+93j BOOTBLK:56B1 ; sub_F54A6+C0j ... BOOTBLK:56B1 66 0F CF bswap edi ; Swap bytes BOOTBLK:56B4 66 C1 C0 10 rol eax, 10h ; Rotate Left BOOTBLK:56B8 B9 B8 0B mov cx, 0BB8h BOOTBLK:56B8 BOOTBLK:56BB BOOTBLK:56BB write_loop: ; CODE XREF: SMBus_WriteBlock+23j BOOTBLK:56BB B8 FF 00 mov ax, 0FFh ; value BOOTBLK:56BE BF C4 56 mov di, offset SMB_Read_Host_Status BOOTBLK:56C1 E9 C2 00 jmp SMBus_io_write_SL ; set SMB Host Status BOOTBLK:56C1 BOOTBLK:56C4 ; --------------------------------------------------------------------------- BOOTBLK:56C4 BOOTBLK:56C4 SMB_Read_Host_Status: ; DATA XREF: SMBus_WriteBlock+Do BOOTBLK:56C4 E6 ED out 0EDh, al ; delay BOOTBLK:56C6 B4 00 mov ah, 0 ; reg BOOTBLK:56C8 BF CE 56 mov di, offset SMB_Check_Host_Status BOOTBLK:56CB E9 C0 00 jmp SMBus_io_read_SL ; set SMB_Host_Status BOOTBLK:56CB BOOTBLK:56CE ; --------------------------------------------------------------------------- BOOTBLK:56CE BOOTBLK:56CE SMB_Check_Host_Status: ; DATA XREF: SMBus_WriteBlock+17o BOOTBLK:56CE 24 0F and al, 1111b ; Logical AND BOOTBLK:56D0 3C 00 cmp al, 0 ; No SMB errors BOOTBLK:56D2 74 0C jz short SMBus_WriteByte ; Jump if Zero (ZF=1) BOOTBLK:56D2 BOOTBLK:56D4 E2 E5 loop write_loop ; Loop while CX != 0 BOOTBLK:56D4 BOOTBLK:56D6 66 C1 C8 10 ror eax, 10h ; Rotate Right BOOTBLK:56DA 66 0F CF bswap edi ; Swap bytes BOOTBLK:56DD F9 stc ; Set Carry Flag BOOTBLK:56DE FF E7 jmp di ; Indirect Near Jump BOOTBLK:56DE BOOTBLK:56DE SMBus_WriteBlock endp BOOTBLK:56DE BOOTBLK:56E0 BOOTBLK:56E0 ; =============== S U B R O U T I N E ======================================= BOOTBLK:56E0 BOOTBLK:56E0 BOOTBLK:56E0 SMBus_WriteByte proc near ; CODE XREF: SMBus_WriteBlock+21j BOOTBLK:56E0 B8 D2 04 mov ax, 4D2h ; reg = 0x4; // XMIT_SLVA - Transmit Slave Address BOOTBLK:56E0 ; value = 0xD2; BOOTBLK:56E3 BF E9 56 mov di, offset SMB_Send_CMD BOOTBLK:56E6 E9 9D 00 jmp SMBus_io_write_SL ; Jump BOOTBLK:56E6 BOOTBLK:56E9 ; --------------------------------------------------------------------------- BOOTBLK:56E9 BOOTBLK:56E9 SMB_Send_CMD: ; DATA XREF: SMBus_WriteByte+3o BOOTBLK:56E9 66 C1 C0 08 rol eax, 8 ; Rotate Left BOOTBLK:56ED 0C 80 or al, 80h ; value BOOTBLK:56EF B4 03 mov ah, 3 ; reg = 0x3; // HST_CMD - Host Command BOOTBLK:56F1 BF F7 56 mov di, offset SMB_Send_Data BOOTBLK:56F4 E9 8F 00 jmp SMBus_io_write_SL ; Jump BOOTBLK:56F4 BOOTBLK:56F7 ; --------------------------------------------------------------------------- BOOTBLK:56F7 BOOTBLK:56F7 SMB_Send_Data: ; DATA XREF: SMBus_WriteByte+11o BOOTBLK:56F7 66 C1 C0 08 rol eax, 8 ; value BOOTBLK:56FB B4 05 mov ah, 5 ; reg = 0x5; // HST_D0 - Host Data 0 BOOTBLK:56FD BF 03 57 mov di, offset SMB_Prepare_Controller BOOTBLK:5700 E9 83 00 jmp SMBus_io_write_SL ; Jump BOOTBLK:5700 BOOTBLK:5703 ; --------------------------------------------------------------------------- BOOTBLK:5703 BOOTBLK:5703 SMB_Prepare_Controller: ; DATA XREF: SMBus_WriteByte+1Do BOOTBLK:5703 B8 48 02 mov ax, 248h ; reg = 0x2; // HST_CNT - Host Control BOOTBLK:5703 ; value = 0x48; BOOTBLK:5706 BF 0B 57 mov di, offset loc_F570B BOOTBLK:5709 EB 7B jmp short SMBus_io_write_SL ; Jump BOOTBLK:5709 BOOTBLK:570B ; --------------------------------------------------------------------------- BOOTBLK:570B BOOTBLK:570B loc_F570B: ; DATA XREF: SMBus_WriteByte+26o BOOTBLK:570B B9 10 27 mov cx, 2710h BOOTBLK:570B BOOTBLK:570E BOOTBLK:570E delay_loop: ; CODE XREF: SMBus_WriteByte+30j BOOTBLK:570E E6 ED out 0EDh, al BOOTBLK:5710 E2 FC loop delay_loop ; Loop while CX != 0 BOOTBLK:5710 BOOTBLK:5712 B8 FF 00 mov ax, 0FFh ; value BOOTBLK:5715 BF 1A 57 mov di, offset return BOOTBLK:5718 EB 6C jmp short SMBus_io_write_SL ; Jump BOOTBLK:5718 BOOTBLK:571A ; --------------------------------------------------------------------------- BOOTBLK:571A BOOTBLK:571A return: ; DATA XREF: SMBus_WriteByte+35o BOOTBLK:571A 66 0F CF bswap edi ; Swap bytes BOOTBLK:571D F8 clc ; Clear Carry Flag BOOTBLK:571E FF E7 jmp di ; Indirect Near Jump BOOTBLK:571E BOOTBLK:571E SMBus_WriteByte endp BOOTBLK:571E BOOTBLK:5720 BOOTBLK:5720 ; =============== S U B R O U T I N E ======================================= BOOTBLK:5720 BOOTBLK:5720 BOOTBLK:5720 SMBus_ReadBlock proc near ; CODE XREF: sub_F54A6+ACj BOOTBLK:5720 66 0F CF bswap edi ; Swap bytes BOOTBLK:5723 66 C1 C0 10 rol eax, 10h ; Rotate Left BOOTBLK:5727 B9 B8 0B mov cx, 0BB8h BOOTBLK:5727 BOOTBLK:572A BOOTBLK:572A read_loop: ; CODE XREF: SMBus_ReadBlock+21j BOOTBLK:572A B8 FF 00 mov ax, 0FFh BOOTBLK:572D BF 32 57 mov di, offset SMB_Read_Host_Status BOOTBLK:5730 EB 54 jmp short SMBus_io_write_SL ; Jump BOOTBLK:5730 BOOTBLK:5732 ; --------------------------------------------------------------------------- BOOTBLK:5732 BOOTBLK:5732 SMB_Read_Host_Status: ; DATA XREF: SMBus_ReadBlock+Do BOOTBLK:5732 E6 ED out 0EDh, al BOOTBLK:5734 B4 00 mov ah, 0 BOOTBLK:5736 BF 3B 57 mov di, offset SMB_Check_Host_Status BOOTBLK:5739 EB 53 jmp short SMBus_io_read_SL ; Jump BOOTBLK:5739 BOOTBLK:573B ; --------------------------------------------------------------------------- BOOTBLK:573B BOOTBLK:573B SMB_Check_Host_Status: ; DATA XREF: SMBus_ReadBlock+16o BOOTBLK:573B 24 0F and al, 0Fh ; Logical AND BOOTBLK:573D 3C 00 cmp al, 0 ; Compare Two Operands BOOTBLK:573F 74 0C jz short SMBus_ReadByte ; Jump if Zero (ZF=1) BOOTBLK:573F BOOTBLK:5741 E2 E7 loop read_loop ; Loop while CX != 0 BOOTBLK:5741 BOOTBLK:5743 66 C1 C8 10 ror eax, 10h ; Rotate Right BOOTBLK:5747 66 0F CF bswap edi ; Swap bytes BOOTBLK:574A F9 stc ; Set Carry Flag BOOTBLK:574B FF E7 jmp di ; Indirect Near Jump BOOTBLK:574B BOOTBLK:574B SMBus_ReadBlock endp BOOTBLK:574B BOOTBLK:574D BOOTBLK:574D ; =============== S U B R O U T I N E ======================================= BOOTBLK:574D BOOTBLK:574D BOOTBLK:574D SMBus_ReadByte proc near ; CODE XREF: SMBus_ReadBlock+1Fj BOOTBLK:574D B8 D3 04 mov ax, 4D3h ; reg = 0x4; // XMIT_SLVA - Transmit Slave Address BOOTBLK:574D ; value = 0xD3; BOOTBLK:5750 BF 55 57 mov di, offset SMB_Send_CMD BOOTBLK:5753 EB 31 jmp short SMBus_io_write_SL ; Jump BOOTBLK:5753 BOOTBLK:5755 ; --------------------------------------------------------------------------- BOOTBLK:5755 BOOTBLK:5755 SMB_Send_CMD: ; DATA XREF: SMBus_ReadByte+3o BOOTBLK:5755 66 C1 C0 08 rol eax, 8 ; Rotate Left BOOTBLK:5759 0C 80 or al, 80h ; Logical Inclusive OR BOOTBLK:575B B4 03 mov ah, 3 ; reg = 0x3; // HST_CMD - Host Command BOOTBLK:575D BF 62 57 mov di, offset SMB_Prepare_Controller BOOTBLK:5760 EB 24 jmp short SMBus_io_write_SL ; Jump BOOTBLK:5760 BOOTBLK:5762 ; --------------------------------------------------------------------------- BOOTBLK:5762 BOOTBLK:5762 SMB_Prepare_Controller: ; DATA XREF: SMBus_ReadByte+10o BOOTBLK:5762 B8 48 02 mov ax, 248h ; reg = 0x2; // HST_CNT - Host Control BOOTBLK:5762 ; value = 0x48; BOOTBLK:5765 BF 6A 57 mov di, offset loc_F576A BOOTBLK:5768 EB 1C jmp short SMBus_io_write_SL ; Jump BOOTBLK:5768 BOOTBLK:576A ; --------------------------------------------------------------------------- BOOTBLK:576A BOOTBLK:576A loc_F576A: ; DATA XREF: SMBus_ReadByte+18o BOOTBLK:576A B9 30 75 mov cx, 7530h BOOTBLK:576A BOOTBLK:576D BOOTBLK:576D delay_loop: ; CODE XREF: SMBus_ReadByte+22j BOOTBLK:576D E6 ED out 0EDh, al BOOTBLK:576F E2 FC loop delay_loop ; Loop while CX != 0 BOOTBLK:576F BOOTBLK:5771 B8 FF 00 mov ax, 0FFh BOOTBLK:5774 BF 79 57 mov di, offset SMB_Read_Data BOOTBLK:5777 EB 0D jmp short SMBus_io_write_SL ; Jump BOOTBLK:5777 BOOTBLK:5779 ; --------------------------------------------------------------------------- BOOTBLK:5779 BOOTBLK:5779 SMB_Read_Data: ; DATA XREF: SMBus_ReadByte+27o BOOTBLK:5779 B4 05 mov ah, 5 ; reg = 0x5; // HST_D0 - Host Data 0 BOOTBLK:577B BF 80 57 mov di, offset return BOOTBLK:577E EB 0E jmp short SMBus_io_read_SL ; Jump BOOTBLK:577E BOOTBLK:5780 ; --------------------------------------------------------------------------- BOOTBLK:5780 BOOTBLK:5780 return: ; DATA XREF: SMBus_ReadByte+2Eo BOOTBLK:5780 66 0F CF bswap edi ; Swap bytes BOOTBLK:5783 F8 clc ; Clear Carry Flag BOOTBLK:5784 FF E7 jmp di ; Indirect Near Jump BOOTBLK:5784 BOOTBLK:5784 SMBus_ReadByte endp BOOTBLK:5784 BOOTBLK:5786 BOOTBLK:5786 ; =============== S U B R O U T I N E ======================================= BOOTBLK:5786 BOOTBLK:5786 BOOTBLK:5786 ; void __usercall SMBus_io_write_SL(__int8 reg<ah>, __int8 value<al>) BOOTBLK:5786 SMBus_io_write_SL proc near ; CODE XREF: SMBus_WriteBlock+10j BOOTBLK:5786 ; SMBus_WriteByte+6j ... BOOTBLK:5786 BA 00 04 mov dx, 400h BOOTBLK:5789 8A D4 mov dl, ah BOOTBLK:578B EE out dx, al BOOTBLK:578C FF E7 jmp di ; Indirect Near Jump BOOTBLK:578C BOOTBLK:578C SMBus_io_write_SL endp BOOTBLK:578C BOOTBLK:578E BOOTBLK:578E ; =============== S U B R O U T I N E ======================================= BOOTBLK:578E BOOTBLK:578E BOOTBLK:578E ; __int8 __usercall SMBus_io_read_SL<al>(__int8 reg<ah>) BOOTBLK:578E SMBus_io_read_SL proc near ; CODE XREF: SMBus_WriteBlock+1Aj BOOTBLK:578E ; SMBus_ReadBlock+19j ... BOOTBLK:578E BA 00 04 mov dx, 400h BOOTBLK:5791 8A D4 mov dl, ah BOOTBLK:5793 EC in al, dx BOOTBLK:5794 FF E7 jmp di ; Indirect Near Jump BOOTBLK:5794 BOOTBLK:5794 SMBus_io_read_SL endp BOOTBLK:5794
One more example:
