Don't worry, your English is good enough. And it can be understood much easier than computer translations to Russian, used by some people
Well, first of all, you can try version 4.23 of patcher. You will need these files also:
cbrom.exe lha.exe reall.cod amibcp.exe
You can try even v6 alpha 10 - but only if you have an opportunity to reflash BIOS somewhere else in case of errors. Just because it is completely rewritten alpha version and it is not giving stable results everywhere.
Also, it will be a good idea to post here the patching log.
cbrom.exe
lha.exe
reall.cod
amibcp.exe
