СМАРТ ------------------------------------------------------------------------- ID Name Value Worst Tresh Raw Health ------------------------------------------------------------------------- 1 Raw
СМАРТ
1 Raw read error rate 200 200 51 2 •••••
3 Spin-up time 216 108 21 2158 •••••
4 Number of spin-up times 98 98 0 2530 ••••
5 Reallocated sector count 200 200 140 0 •••••
7 Seek error rate 200 200 0 0 •••••
9 Power-on time 88 88 0 8966 ••••
10 Spin-up retries 100 100 0 0 •••••
11 Recalibration retries 100 100 0 0 •••••
12 Start/stop count 98 98 0 2509 ••••
192 Power-off retract count 198 198 0 1755 •••••
193 Load/unload cycle count 170 170 0 90157 •••••
194 HDA Temperature 114 90 0 33°C/91°F ••••
196 Reallocated event count 200 200 0 0 •••••
197 Current pending sectors 200 200 0 0 •••••
198 Offline scan UNC sectors 200 200 0 7 •••••
199 Ultra DMA CRC errors 200 200 0 0 •••••
200 Multi zone error rate 200 200 0 5 •••••
PASSPORT
Model: WDC WD10EARS-00Y5B1
Firmware: 80.00A80
Serial: WD-WCAV56008949
Disk size: 1953525168 LBAs 953869 Mb
CHS: 16383/16/63 8063 Mb
SMART: Enabled, Errlog, Selftest
CACHE: Unk.size; L/A=ON; Wr=ON; ok
Support: LBA, HPA, AAM, DLM, DMA UDMA-6
AAM val: 254 Maximum
Erase: ~208 minutes
Security: OFF
ATA-8: SATA2, NCQ, PEC, SCT, SFDLM
TEST
0:27:12 : Starting Reading, LBA=0..1953525167, sequential access, timeout 10000ms
0:27:16 : Block 0 Error: ABRT
0:27:20 : Block 256 Error: ABRT
0:27:24 : Block 512 Error: ABRT
0:27:28 : Block 768 Error: ABRT
0:27:32 : Block 1024 Error: ABRT
0:27:32 : Command interrupted by user!
Закладка Адванс - Deter Mine RPM
SEEK TEST /
Помогите проблема с Винтом WD 1ТБ, Оч нужно!!!!!
