Supports 512-Mb, 1-Gb, 2-Gb DDR2 and 512-Mb, 1-Gb DDR3 DRAM technologies for x8 and x16 devices.
• Using 512 Mb device technologies, the smallest memory capacity possible is 256 MB, assuming Single Channel Mode with a single x16 single sided un-buffered non-ECC DIMM memory configuration.
• Using 2 Gb device technologies, the largest memory capacity possible is 16 GB, assuming Dual Channel Mode with four x8 double sided un-buffered non-ECC or ECC DIMM memory configurations.
NOTE: The ability to support greater than the largest memory capacity is subject to availability of higher density memory devices.
Т.е. явное упоминание DDR3 SDRAM - для 1 Гбит, но упоминание 2 Гбит - без явной привязки именно к DDR2 SDRAM. И примечание.
Если поглядеть в Memory QVL для плат на G41, то есть упоминания модулей DDR3 SDRAM на 4 Гб.
