биос от NightShade
copy /b BIO+BI1+BI2+BI3+BI4+BI5+FF64+BI6 bios.rom
-=PhoenixDeco, version 0.31 (DOS)=- Filelength : 80000 (524288 bytes) Filename : bios.rom PhoenixBIOS hook found at : 7761E System Information at : 7768A BootBlock : 4000 bytes BankSize : 1024 KB Version : DEVEL80K Start : 7F3BD Offset : 70000 BCP Modules : 22 BCPFCP : 7FF00 FCP 1st module : 67E (7067E) Released : 21 January 2000 at 10:23:18 /* Copyrighted Information */ PhoenixBIOS 4.0 Release 6.0 /* ----------------------- */ +------------------------------------------------------------------------------+ | Class.Instance (Name) Packed ---> Expanded Compression Offset | +------------------------------------------------------------------------------+ B.03 ( BIOSCODE) 06379 (25465) => 07860 ( 30816) LZSS ( 82%) 160Eh B.02 ( BIOSCODE) 08EDC (36572) => 0BBE0 ( 48096) LZSS ( 76%) C005h C.00 ( UPDATE) 04010 (16400) => 04010 ( 16400) NONE (100%) 2289Bh R.02 ( OPROM) 05353 (21331) => 07400 ( 29696) LZSS ( 71%) 268C6h R.01 ( OPROM) 05D85 (23941) => 08000 ( 32768) LZSS ( 73%) 2BC34h B.01 ( BIOSCODE) 056CB (22219) => 069F0 ( 27120) LZSS ( 81%) 34EFCh A.01 ( ACPI) 00C87 (03207) => 02199 ( 8601) LZSS ( 37%) 3F363h R.00 ( OPROM) 09402 (37890) => 0D000 ( 53248) LZSS ( 71%) 519D4h E.00 ( SETUP) 0458C (17804) => 089D4 ( 35284) LZSS ( 50%) 5ADF1h S.00 ( STRINGS) 10C52 (68690) => 1FB11 (129809) LZSS ( 52%) 5F398h A.00 ( ACPI) 00C96 (03222) => 021B2 ( 8626) LZSS ( 37%) 70769h X.00 ( ROMEXEC) 06B50 (27472) => 06B50 ( 27472) NONE (100%) 7141Ah R.03 ( OPROM) 01849 (06217) => 04000 ( 16384) LZSS ( 37%) 78986h X.01 ( ROMEXEC) 014B0 (05296) => 014B0 ( 5296) NONE (100%) 7A1EAh B.00 ( BIOSCODE) 00604 (01540) => 08080 ( 32896) LZSS ( 4%) 7B6B5h A.02 ( ACPI) 0005C (00092) => 00074 ( 116) LZSS ( 79%) 7BCD4h T.00 ( TEMPLATE) 0365C (13916) => 07090 ( 28816) LZSS ( 48%) 7BD4Bh D.00 ( DISPLAY) 00C18 (03096) => 00F00 ( 3840) LZSS ( 80%) 7F3C2h Total Sections: 18
биос от NightShade
получаем файл объемом 458572 байтов, а при натравливании на него phnxdeco имеем
прелесть 8) Зовите Романа!
