Что имеется в виду? Так значит CPUCODE.BIN который у меня появляется в дирректории после пропатчивания надо зашивать в пропатченый биос? Получается я лью прошивку вообще без CPUCODE.BIN?
Не, смотри
bp-4rc_F.exe 6va7p.bin /p /s /v
Microsoft(R) Windows DOS
(C)Copyright Microsoft Corp 1990-1999.
BIOS_Patcher ver. 4.0_RC.F from "Second_Hope utils".
Warning! Recommended for power-users!
Found 2Mbit BIOS (4.5x)!
Warning - found Gigabyte-BIOS!
Remove GA-blocking "+PCI" in BootBlockRemove GA-blocking "+PCI" in BootBlockRemove "otkat"
1. New CPU Support : -> fixed.
2. P3-detect error : not request to fixed.
3. New Koeffs Support :> -> fixed.
4. 32Gb-problem(32g) : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : not request to fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : not request to fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Add "+PCI"-menu in BIOS Setup.
Remove GA-blocking "+PCI" in BIOS SetupAdding timings-tweak.Adding "Turbo RAM"-tweak.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 30.1%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
Warning! BootBlock was changed! Flashing BIOS only WITH BootBlock!
(c)2002 apple_rom, www.ROM.by
Как видишь цпукод добавился, проверяем:
bp-4rc_F.exe 6va7p.bin /e
BIOS-PartName Segm:Offs Compress/Real_Size "Official" name - what`s meanining
awardext.rom 4100:0000 0000:448B/0000:6690 "awardext.rom" - ALT part
ACPITBL.BIN 4003:0000 0000:0D95/0000:22AC "ACPITBL.bin" - ACPI table
AwardBmp.bmp 4002:0000 0000:02E5/0000:168C "awardepa.bmp" - EPA picture
g400-15.bin 4080:0000 0000:4CB0/0000:8000 "VGA.rom" - video-BIOS
ncr307.16k 4086:0000 0000:256E/0000:4000 "PCI.rom" ~ SCSI-BIOS
modul.tmp 4E00:0000 0000:0457/0000:0E6E "modul.tmp" - BIOS Patcher file
start.tmp 2D05:000A 0000:001C/0000:0020
cpucode.bin 4001:0000 0000:54FE/0000:9800 "cpucode.bin" - microcodes
6va7p.BIN 5000:0000 0001:57F7/0002:0000 "original.tmp" - MAIN part
CPU_microcodes (CPUID/version/type):
06B4>0001/Sock 06B1>001C/Sock 068A>0001/Sock 0686>0008/Sock 0686>0007/Slot 0683>0014/Sock 0683>0013/Slot 0681>0011/Sock 0681>000D/Slot 0673>000E/Slot 0672>0010/Slot 0665>0003/Sock 0660>000A/Slot 0653>0010/Slot 0652>002A/Slot 0651>0040/Slot 0650>0040/Slot 0634>0035/Slot 0633>0034/Slot
Все в порядке
Как я понял патчер просто делает дополнительный модуль с исправлениями которые накладываются во время загрузки, получается он его создает под именем CPUCODE.BIN и автоматом в прошивку не запихивает?
Что-то я совсем запутался
CPUCODE.BIN это микрокоды проца, другие изменения храняться в start.tmp и modul.tmp
Конечно для всех наверное BIOS отредактировать плевое дело, но я что-то в процедуре использования патчера помоему застрял.
У меня пропатченый биос не грузиться. Если CPUCODE сам собираю и в биос запихиваю машина не грузиться.
Ничего запихивать не надо, попробуй еще раз.
Кстати, может у кого есть уже протвиканый биос для этой мамы с которым она грузиться?
У меня есть уже зашитый, только я не проверял ничего кроме рамтвика, который мало что дает, и тачка эта круглосуточно занята.
Не, смотри
Все в порядке
