Есть для 2k и для XP на M5289, мб прикрутишь ими свой m5283.
Млин, прикрутил драйвер к новосозданному ядру 2.4.32, но что-то так и не увидел своего RAID Ali m5283 и винта котрый на нём висит тоже не увидаль=(
[root@FTP dev]# dmesg Linux version 2.4.32 (root@FTP) (gcc version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)) #3 Срд Фев 22 04:09:40 VLAT 2006 BIOS-provided physical RAM map: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable) BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved) BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved) BIOS-e820: 0000000000100000 - 0000000004000000 (usable) BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved) 64MB LOWMEM available. On node 0 totalpages: 16384 zone(0): 4096 pages. zone(1): 12288 pages. zone(2): 0 pages. Kernel command line: BOOT_IMAGE=RH9(2.4.32) ro root=1601 BOOT_FILE=/boot/vmlinuz-2.4.32 Initializing CPU#0 Detected 167.045 MHz processor. Console: colour VGA+ 80x25 Calibrating delay loop... 333.41 BogoMIPS Memory: 62324k/65536k available (1336k kernel code, 2824k reserved, 496k data, 72k init, 0k highmem) Dentry cache hash table entries: 8192 (order: 4, 65536 bytes) Inode cache hash table entries: 4096 (order: 3, 32768 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 16384 (order: 4, 65536 bytes) Intel Pentium with F0 0F bug - workaround enabled. CPU: After generic, caps: 008001bf 00000000 00000000 00000000 CPU: Common caps: 008001bf 00000000 00000000 00000000 CPU: Intel Pentium MMX stepping 03 Checking 'hlt' instruction... OK. POSIX conformance testing by UNIFIX PCI: PCI BIOS revision 2.10 entry at 0xfb440, last bus=0 PCI: Using configuration type 1 PCI: Probing PCI hardware PCI: Probing PCI hardware (bus 00) Disabling direct PCI/PCI transfers. isapnp: Scanning for PnP cards... isapnp: No Plug & Play device found Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd Installing knfsd (copyright (C) 1996 ). udf: registering filesystem pty: 256 Unix98 ptys configured Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI ISAPNP enabled ttyS00 at 0x03f8 (irq = 4) is a 16550A ttyS01 at 0x02f8 (irq = 3) is a 16550A Floppy drive(s): fd0 is 1.44M FDC 0 is a post-1991 82077 [drm] Initialized tdfx 1.0.0 20010216 on minor 0 [drm] Initialized radeon 1.7.0 20020828 on minor 1 Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4 ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx hda: ASUS DVD-ROM DVD-E616P 0104, ATAPI CD/DVD-ROM drive hdc: FUJITSU MPC3032AT, ATA DISK drive ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 ide1 at 0x170-0x177,0x376 on irq 15 hdc: attached ide-disk driver. hdc: 6346368 sectors (3249 MB), CHS=6296/16/63 hda: attached ide-cdrom driver. hda: ATAPI 24X DVD-ROM drive, 256kB Cache Uniform CD-ROM driver Revision: 3.12 Partition check: hdc: [PTBL] [395/255/63] hdc1 hdc2 Initializing Cryptographic API NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 4096 bind 8192) NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. VFS: Mounted root (ext2 filesystem) readonly. Freeing unused kernel memory: 72k freed Adding Swap: 128512k swap-space (priority -1) Intel(R) PRO/1000 Network Driver - version 5.7.6-k1-NAPI Copyright (c) 1999-2004 Intel Corporation. e1000: eth0: e1000_probe: Intel(R) PRO/1000 Network Connection e1000: eth0: e1000_watchdog: NIC Link is Up 100 Mbps Full Duplex [root@FTP dev]#
Добавлено спустя 2 часа 8 минут 54 секунды:
Всё собралось на RH9.0! Никто не поможет поправить дровишки на FreeBSD? Исходники... personal.primorye.ru/lsv/32bit_driver.rar checksum: 64,5 КБ (66 084 байт)
P.S. Кому там дрова под Масдай нужны? Держите... personal.primorye.ru/lsv/M5289_V.5.0.2.7.rar checksum: 1,19 МБ (1 255 620 байт)
Исходники...
