1#через терминал (что за винда/линух стоит?)
2#или квик диаг / диагностика или как ее там...
ATI3 -Modem returns Product ID string. The string contains the Company name, the Product line name and the speed of the product. Additionally, some special features like FAX and VOICE will also be listed
ATI4-Modem sends one screen of data to the DTE indicating the present configuration of the following settings:
B, E, F, M, Q, V and X commands
DTE baud rate, parity, word length, dial type (pulse or tone), and H setting (On or Off Hook) .
&A, &B, &C, &D, &G, &H, &I, &K, &M, &N, &P, &R, &S, &T, and &Y
S register values from (S0 S42)
LAST DIALED #:
ATI6-Modem sends diagnostic screen to DTE with the following information from the previous data connection:
Numbers of characters sent, received, lost.
Numbers of octets (compressed characters) sent, received.
Numbers of blocks sent, received, resent.
Numbers of retrains requested, granted.
Number of line reversals.
Numbers of protocol blocks in error.
Numbers of link timeouts, link "naks".
Negotiated settings for: data compression (on/off), equalization (long/short contained in S15 bit 1).
Fallback enabled/disabled (indicates whether modem negotiated a fallback during connection).
Error Correcting Protocol (LAPM, MNP or NONE).
DCE speed.
Disconnect reason.
Duration of the last call.
LAST DIALED #:
DCE speed.
Disconnect reason.
итд..в нете полно инфы...
