Help me repair mainboard
you can help me repair mainboard ok???
Moved from here.
Рекомендуется к прочтению по той же теме
Аватар пользователя Dr.Rer.Nat
What happens than?:)
What's the problem? Can you tell the model of a mobo at least...
I do not understand the reason why the cpu is not working.'ve fully checked the source. Please give me comments
note: mainboard MSI G41-P28 7592-5.2
thanks.
What do you mean "CPU is not working"? Is CPU_Vcore present?
Is DDR power (1.5V) present?
tell us the name of PWM controller of CPU VRM (a chip in qfn-package near socket)
Is your CPU Ok, and does it supported by this mobo? Check in CPU support list on official MSI website
I checked the source vCore ok! but the problem is, the cpu does not work, test card show FF, I checked the h_cpurst # 0.2v, compare well with the mainboard h_cpurst # 1.2v
anyone can give me study material mainboard repair, I was a repairman, but I need to know the principles of operation of a mainboard, I was out of warranty staff for MSI mainboard in Vietnam
is this cpu supported by the mainboard?
What about CPU_CLK?
It is commonly accepted to publish results of measurements here, including voltage values, signal names / component positional numbers. So feel free, exact values gain successful repairment:)
Relating to your question about learning materials. There is a series of excellent documets from ASUS exists, you cat try to find it via google using "MB Lx Training Materials", where x is a number of a document. Check this, for example
thank you very much, I have seen many articles in rom.by the mainboard or, but I do not know where to find it, you can just give me (give me the link to download the no ). thank you
everything is much simpler, numbers are 1,2,3
part1
part2
part3
thank you a lot, you can give me more keywords to search for learning materials not edit mainboard. I want to better understand the principles of operation mainboard. I thank you
