Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
еще попались вот какието D209L в корпусе как 2sc2625
ктонить знает что это такое?
_________________
СХЕМЫ БП ATX techlabs.nm.ru/
СХЕМЫ БП ATX http//techlabs.nm.ru/
походу дела так D304X 12A/400V/450V
dzsc.com/product/in.....56443.html
_________________
Теперь понятно почему дохнут на ровном месте, 12A/400V/450V допустимое колектор-база, это акурат впритык. А с нашими электорсетями такое не проходит, надо хотябы в полтора раза запас оставлять.
Вобщем нарвался я на дохлый транзюк 20N60C3. Скачал даташит alldatasheet.com/da.....D/HGTG20N6 ... . Перевый раз вижу такое символьное обозначение с двумя стрелками. Что это за зверь, объясните пожалуйста.
_________________
Лужу, паяю, ЭВМ починяю!
Дык это IGBT - Insulated Gate Bipolar Transistor, тобиш биполярный транзистор с изолированным затвором.
Фактически гибрид ежа с ужом, в смысле полевика с биполяром, очень распространены в системах управления мощными электро-движками(тролейбусы, трамваи, метро).
В таких случаях я ищу как подключены К и Э чтобы определить где напруга больше - можно сделать вывод о PNP или NPN.
Вот ешо:
2T = HT 2 Silicon NPN-transistor SMD, Uni, 90V, 0,1A, 0,3W, <500/2000ns
Если инет нормальный - скачай себе VRT2005 на будущее monitor.espec.ws/section13/topic64234.html
_________________
--== Михаил ==--
--== Михаил ==--
UPS PLUS SYSTEMS model BROZER 600. Сгорел транзистор 65N06, он у нас в дефиците. Поскажите пожалуйста ,если кто знает, чем можно его заменить?
Предполагаю - это N-Mosfet 65В 6A
Ищи аналог среди IRF
www.irf.com
Например IRF840 8A, 500V, 0.850 Ohm, N-Channel Power MOSFET TO-220
Это N-кананальный полевик 55V 63A.
Аналогов вагон:
FQA65n06 -> IRFP054
FQA65n06 -> STH75N06
FQAF65n06 -> STH75N06FI
FQB65n06 -> STB60NE06-16
FQB65n06 -> SUB60N06-18
FQB65n06 -> SUB70N04-10
FQB65n06 -> STB60NF06T4
FQP65n06 -> IRFZ48
FQP65n06 -> IRFZ48N
FQP65n06 -> STP60NF06
FQPF65n06 -> IRFIZ48G
FQPF65n06 -> STP60NF06FP
Может вот это? тогда это IGBT
или всё-таки вот это? тогда это мосфет
2 Spectre: синхронно, однако
_________________
