Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
В ноутбучном блоке питания похоже сдох этот транзистор. БП себя ведет так - включаю его а он переодически щелкает (раз в 2-3 секунды) и моргает светодиодом. Транзистор стоит рядом с 1M0880. Транзистор похоже дохлый, потому как я его закрываю, но он тутже открывается и сопротивление быстро растет до закрытого. Хочу поменять его, но у меня такого нету, а в магазин незная аналогов идти тоже неохото. Интернет что-то ничего мне про него не рассказал. Просьба рассказать какие у него аналоги и что за зверь, может даташит покажете.
Даташитка:
doc.chipfind.ru/html/toshiba/2sk2842.html
Аналоги: STP11NK50ZFP, STP8NM50FP, IRFB11N50A, SPA07N60C3
Господа, есть сгоревший транзистор O2N50P чем его можно заменить? (оригинал стоит 150-250р, Москва, "Чир-Дип", только на заказ)
Стоит на одном радиаторе с ключевыми транзисторами в БП ПК (корпус - ТО220), предположительно, в цепи - stand by.
На предыдущей странице был похожий вопрос о идентификации.... - 20N60C3, но аналог назван - не был.
Любой полевик типа 2N6, 4N6 - пример SSP2N6. Ваш - 2А 500В.
Итересует вопрос КП946Б vs (13007 & 13009). Кто круче "Рембо" или "терминатор" Или если серьезно то по частотным характиристикам, если у БП Задрать частоту... перемотать транс-кто лучше себя будет чуствовать? ИМХО полевик, но не ясно... кста какая у полевика все таки мощность? или еще по-другому вопрос-где в инете найти нормальный полные характеристики на КП946?
Что сказали татары прийдя на Русь? "Сдавайтесь русские-нас орда!"
И что им ответили русские?
"А нас-рать!" ) (с)
Ага, иллюстрация к теме "почему я не использую отечественную элементную базу" - не найти никакой документации на нее, никто ничего не гарантирует.
Поиск хоть каких-нибудь параметров дает удивительную картину: КП946Б рассчитан на напряжение С-И макисмум 200 вольт, а по другим источникам - на 300, КП946А - 400 В, по другим источникам - 500В .
Что-то мне подсказывает, что не стоит эти полевики с буковкой Б ставить.
Ну, хоть какие вообще стоит ставить? Можно и импортные, я ж не зацыкливаюсь на именно этих. Главное чтоб они шустро переключались, и держали мощность. Шустро переключаются - значит меньше греются. В схемотехнике БП какое управляющее напряжение/ток для ключей? ИМХО явно не 12-20вольт для полевиков... Грубо говоря, как сделать, чтоб или биполярник переключался быстро, или как переделать, чтоб поставить полевик?
"А нас-рать!" ) (с)
Вопрос: а зачем? Чем не устраивает штатная схема на нормальных транзисторах?
Ставлю mje13007 вместо С4242 уже заметна разница-13007 медленне переключаеться. Vce(sat)(13007)=2v, Vce(sat)(4242)=1v. частоты 80-100кГц. если 120-130кГц Биполярники никуда не годяться...
п.с. я вообще непонимаю почему делают БП на 400Вт с огроменным трансом и биполярными ключами по 3$ каждый... если можна 200кГц с трансом в полтора раза меньшим, и на полевиках.
"А нас-рать!" ) (с)
Зато в два с линим раза мощнее:)
Можно, конечно, только дороже. Элементная база коренным образом меняется.
Откройте любой новый FSP с APFC и сравните, скажем, с LPK2-30.
