Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
ну или 6N60, 7N60...
Вот возник вопрос по замене мощных транзисторов в БП Velton 400Ватт
Стоят D209L Ucb 700B Uce 400B Iс 12A Pc130W
В местных магазинах их нет
Нашел 2SC2625 Ucb 450B Uce 400B Ic 10A Pc 80W
Вижу что максимальная мощность коллектора в полтора раза меньше но эти транзисторы стояли в Powerman' e 430Вт. Как-то не очень понятно - или Powerman сделан в китайском гараже или все-таки допустимо их поменять. Считал что мощность ключевых транзисторов должна быть не меньше чем (Pmax/КПД)/2
Прошу немного разъяснить этот вопрос
Bear2011, не обращайте на этот факт слишком большого внимания. Рассеиваемая мощность 120Вт приводится при условии применения соответственной системы охлаждения, т.е. при определённой температуре транзистора. Транзистор 3DD209L является аналогом транзистора 13009 в корпусе TO-3PN, у которого заявленная максимальная мощность, если не ошибаюсь, 100Вт. В Вашем блоке лучше применить 2SC3320, у него рассеиваемая мощность тоже ниже, хотя ток на три ампера выше. у них недостаток - большая цена. В блоках до 400Вт можно применить и 2SC2625.
reset
Спасибо за консультацию. А 13009 у меня есть. Правда тогда я совсем ничего не понимаю 13009 стояли в ColorsIT'e 330Вт. Поэтому даже не рассматривал их как вариант. Еще раз спасибо
D209L менее надежный чем 2SC2625. Ставьте спокойно.
незнаю клал ссылку кто или нет. здесь справочник по транзисторам 2SC... я его правда под себя в Excel переделал, очень удобно!
транзисторы 2SC...
В Excel: Транзисторы биполярные типа 2SC проводимости n-p-n
я в БП (чаще FSP) 350-450W ставлю вместо сдохших 209L KSE13009 (корпус TO-247) все работает годами! По поводу максимальной рассеиваемой мощности даже не парьтесь при нормальном режиме работы она не превышает 40 Вт, смотреть надо на максимальный импульсный ток и время включения/выключения (On/Fall time), именно в этом режиме работает транзистор в БП
Сгорел БП Hunt Key HK-700-52PP. Обуглился дроссель APFC и сгорел один из полевиков W25nm50n , может кто знает аналог этого мосфета и дроселя ,и где его можно купить в минске
мде, вот такие вот дела>>>
ebay.com/itm/15pcs-Transistor-13009-G-32-/160819784231?pt=LH_DefaultDomain...
ebay.com
item: 13009
15 pcs
price: US $2.34
Shipping: $6.00 Standard Int'l Shipping
Leviafan, а на фотке 13007.
