Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Аватар пользователя egor-land
Перефразирую вопрос: почему нельзя?
А кто сказал , что нельзя ?
А вот скажите зачем ставить именно эти транзисторы ? У вас других что ли нету или лень до магазина доехать за 02N60P ?
Вы даташиты смотрели ? Предельные параметры сравнивали ?
Если сравнивали , то покажите наглядно , что у вас получилось ( в абсолютных единицах в Амперах и Вольтах).
Что такое предельные параметры понимаете ? Это максимальный ток и напряжение , а отнюдь не вольт-амперные характеристики .
А с ними напрямую связаны ещё и другие параметры, которые могут влиять на работоспособность прибора в той или иной схеме включения.
И рисуйте схему, посмотрим что там у вас такое.
Заменил ради эксперимента на рабочем БП 2N60 на К2545, не запустился
Вот тут про K2545 пишут , что работают они нормально вместо 2N60
rom.by/forum/Kruto_ja_popal_na_2N60#new
Вообще пришлось покопаться в запасах, ненужных, ставил k2545 - хорошо пошли
10n60 пришлось пару раз ставить, но они почти впритык раскачиваются
Только надо учитывать , что не во всякой схеме они заведутся и будут нормально работать.
Тут , кстати , об этом уже говорилось rom.by/comment/290051 .
Возможно потребуется переделка схемы - замена нескольких резисторов.
Помогите подобрать аналог 2sk4110 подобное было, но 2sc4110, а у меня пробит 2sk4110.... остальное все так же, в каталогах не значится... все переходы КЗ.
Аватар пользователя UAM
Не встречал. А где они стоят?
Аватар пользователя galec77
pdf
БП ресивера. Маркировка "K4110"
shoppingcart.aliexpress.com/shopcart/shopcartDetail.htm Вот нашел в одном месте. Но это все что на него есть.
Какой там ШИМ, какая потребляемая мощность?
Скорее всего, туда подойдет что-нибудь стандартное 4-8a 600v.
70 Вт. tl3842....
Спасибо! Вы подсказали путь. И по моему, я нашел.Обзвонив все магазины я запаниковал, никто о таком транзисторе не слышал. А по микросхеме нашел схему БП 70Вт(!) схема подобная с транзистором 2SK727. Завтра буду пробовать.
