The DAC output pin is the output of the precision internal DAC reference. The REF input pin is the positive input of the error amplifier. In typical applications, a 1kΩ, 1% resistor is used between DAC and REF to generate a precise offset voltage.
Вывод 10 в SOIC-28 или 7 в QFN-32. Это на будущее.
