Вдруг кому-то полезно будет, распиновка Dell-овского BT-модуля RD530:
Pin#
Module Pin Name
Usage for Platforms
Description
1
GND
GND
Ground
2
USB_D+
USB_D+
USB Data +. Must be routed with USB_D- as a 90 Ohm differential pair.
3
USB_D-
USB_D-
USB Data-. Must be routed with USB_D+ as a 90 Ohm differential pair.
4
USB_PWR
USB_PWR
This is a 5V rail that is used by bus-powered USB devices. The module does not actually draw power from this pin, uses this pin to detect whether the USB host port is powered so as to avoid latch-up conditions.
5
RSVD
Test Point, COEX1
Reserved. This pin may be used for resolving coexistence with the 802.11 radio(s) on the MPCI card in the platform.
6
HW_RADIO_DIS#
HW_RADIO_DIS#
Active low input from the platform to the card to disable all the radios onn the module from transmitting.
7
RSVD
Test Point, COEX2
8
+3.3V
+3V_SUS
This is the rail from which the module powers itself (as a self-powered USB device
9
LED_BT_RadioState
BT_RADIO_ON
Active-high LED drive signal for indicating the state of the Bluetooth Radio. This LED should not have a flashing feature
10
GND
NC
