1. New CPU Support -> fixed.
2. P3-detect error is not needed to be fixed.
3. New Koeffs Support -> fixed.
4. 32Gb-problem not found.
5. Some HDD detect-problem not found.
6. "MB"/"GB" string search is not needed to be fixed.
9. Error display Freq>999MHz is not needed to be fixed.
10.Error display Koefs>9.5x not found.
11.New Stepping Support is not needed to be fixed.
12.Tualatin L2-init error not found.
13.New Freq in Setup open not found.
14.Set "Y" as default oCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 24.3%
Adding start.tmp 87.5%
(c)2002-2003 apple_rom, www.ROM.by
D\komar\PATCHER\PATCH\TEMP>
Ну вот такой вот лог - вроде всё честно....
D\komar\PATCHER\PATCH\TEMP>bp-4_23.exe ali61_14.bin
BIOS Patcher ver. 4.23.
Found 1Mbit BIOS!
