Сам пока не пробовал, но рано или поздно придется -- периодически возникает такая необходимость. :?
Вот выдержки из описания:
BootPart 2.50: Boot Partitions for WinNT
BootPart is an easy tool for adding additional partitions to the Windows NT multi boot menu (for example, add the OS/2 boot manager or a Linux partition).
BOOTPART lets you add partitions to the Windows NT/2K/XP Multiboot menu. Usually, you will only have a MSDOS or Windows 95 entry and one (or several) Windows NT entries on this boot menu.
With BOOTPART, you may add any partition to the menu. You may add an OS/2 Multiboot partition, or a Linux Partition (with Lilo) to this menu.
The only thing I highly suggest is : your active partition on your first hard disk must be a FAT16 primary partition. This may be a small partition.
It seems it's actually impossible add an HPFS partition with OS/2 boot. If you find a workaround, please let me know.
BOOTPART creates a 512 byte file which contains an image of the boot sector that loads the boot sector of the partition. After, this file is declared in C:\BOOT.INI (a text file used by the Windows NT boot menu).
PS: Для полного счастья осталось лишь найти аналог досовской SYS.COM под WinXP
Набрел на тулзу, специально предназначенную для создания сабжевого файла:
ourworld.compuserve.com/homepages/gvollant/bootpart.htm
