I have test the bp6a10 on ABIT KT7
I have test the bp6a10 on ABIT KT7 v1.1 and bios KT7_a9.bin from abit web site!
I am Italian, and write bad english!
the result:
I play with my KT7 for 1 years with bp4.51, and never have problem!
Processor AMD Thorthon@Barton 2266Mhz (FBS 133Mhz)
(c)2002-2003 apple_rom, www.ROM.by
C:\bp\>bp-4_51 kt7_a9.bin /x
BIOS Patcher ver. 4.51.
Found 2Mbit BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support : -> fixed.
Mobile AMD Multipl-r adding :0000 -> fixed.
2. XP frequency : Show only REAL frequency (in MHz).
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : found, but Unknown format!
Add new freq in BIOS Setup: 133/33MHz 124/31MHz 130/32MHz
14.Set "Y" as default on exit: not found.
Tweak options addinng:
Bus Disconnect Support : -> fixed.
FID_Enable adding : -> fixed.
Display Features adding : -> fixed.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 37.9%
Adding tweak.tmp 65.5%
Adding start.tmp 87.5%
With new version of bios patcher:
C:\bp\BP_6_A10>_bp kt7_a9.bin /x
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses|
Found 2Mbit Award BIOS (6.x)!
Adding AMDK7NOW! support : -> fixed.
Add new freq in BIOS Setup: 133/33MHz>124/31MHz>130/32MHz>
Adding modul.tmp 43.1%
Adding tweak.tmp 45.2%
(c)2002-2004 apple_rom, www.ROM.by
C:\bp\BP_6_A10>
New version don't fix >>>>>FID_Enable adding<<<<<<<<
Why?
How much the registered version of bios patcher?
|For patching Award/Phoenix/AMI bioses in catalog must be: |
|- cbrom.exe (ver. 2.07 or 2.08 strongly recommended) |
|- lha.exe |
|- reall.cod |
|- amibcp.exe |
|*************************All files you can find on www.ROM.by |
|This options have only registered version: |
|To add file for run in BIOS type: "bp patch_file in_BIOS.run" |
|To add alt lng-file for SETUP type: "bp patch_file in_BIOS.lng" |
|To add changes in BIOS type: "bp patch_file in_BIOS.chg" |
I can have registered version of bios patcher?
Thanks a lot for this work!!
Версия 6.00 - обкатка (часть 2)
