Abit Kt7a v1.3 & bios kt7sb4 works better with new patcher now Memory Interleave 4-way is enabled before (4.51) was no boot up Athlon Xp cpu not tested only Athlon 900
PcChips M571 v3.2 (Socket 7)
pcchipsusa.com/bios/571329421.ZIP
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required!
Found 1Mbit AMI BIOS!
!! Module Manipulation Successful !!
4. 32Gb-problem : not found.
Tweak options addinng:
!! Module Manipulation Successful !! DOS/4G error (2001): exception 0Eh (page fault) at 287:879D5A24 TSF32: prev_tsf32 81C0 SS 28F DS 28F ES 28F FS 0 GS 87
if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by
Any idea?
only Athlon 900
EAX 58E8D302 EBX 8AD51034 ECX 8AD51008 EDX CE13C2CE
ESI 8AD51008 EDI 5 EBP 87A2B5FC ESP 87A2B5B0
CS:IP 287:879D5A24 ID 0E COD 4 FLG 10282
CS= 287, USE32, page granular, limit FFFFFFFF, base 0, acc CFFB
SS= 28F, USE32, page granular, limit FFFFFFFF, base 0, acc CFF3
DS= 28F, USE32, page granular, limit FFFFFFFF, base 0, acc CFF3
ES= 28F, USE32, page granular, limit FFFFFFFF, base 0, acc CFF3
FS= 0, USE16, byte granular, limit 0, base 0, acc 0
GS= 87, USE16, byte granular, limit FFFF, base 21830, acc F3
CR0: unavailable
Crash address (unrelocated) = 1:00016A24
Any idea?
