Intel Flash Memory Update Utility Part 643643-046
GUI-mode options:
/m - Monochrome display /b - Use BIOS video calls
/t - Use EGA/VGA line count /n - Do not use pointer device
Command-line mode options:
/h - Help (this text)
/q - Quiet mode; errors only, and no prompts
/qb - Quiet mode; No beeps
Standard options:
/r - Force reboot after update /@ - Use override file
/f - Force CMOS defaults next POST /d - Verbose debugging output
/c - Clear ESCD (Extended System Configuration Data) next POST
/p pathname - Program FLASH device with contents of 'pathname'.
/pu pathname - Program User Binary area with contents of 'pathname'.
/v pathname - Verify current FLASH with contents of 'pathname'.
/sX pathname - Save resident FLASH area to 'pathname' (or 'vvvv'BIOS),
X = { 'B'IOS, 'L'anguage, 'U'ser, or 'R'ecovery } area.
/x pathname - eXamine FLASH header of 'pathname'.
Special Operations:
/v pathname - Verify current flash with contents of 'pathname.'
/x pathname - eXamine flash header of 'pathname'.
/sX pathname - Save resident flash area to 'pathname' (or 'vvvv'BIOS)
X = { 'B'IOS, 'L'anguage, 'U'ser, 'R'ecovery } area.
/ae - Erase OEM CMOS Defaults.
/ac - Copy Custom CMOS Defaults into the OEM CMOS Defaults.
/af - Force OEM CMOS Defaults next POST.
/ag pathname - Get OEM CMOS Defaults to 'pathname'.
/as pathname - Set OEM CMOS Defaults with contents of 'pathname'.
/ew pathname - Write BMI settings with contents of 'pathname'.
/er pathname - Retrieve BMI settings to 'pathname'.
Вот что выдал Iflash.exe от платы D845GVAD2:
