Как и многим здесь нужно заставить работать SATA винт мат. плата Albatron PX848PV без sata на борту. контроллер на VIA6421. Операционка винт видит, БИОС - нет
CBROM182.exe V1.82 [04/11/07] (C)Phoenix Technologies 2001-2007
******** 48pv110.bin BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
================================================================================ 0. System BIOS 20000h(128.00K)145B9h(81.43K)BIOS.BIN
1. XGROUP CODE 0BEB0h(47.67K)087E0h(33.97K)awardext.rom
2. CPU micro code 05000h(20.00K)04DCDh(19.45K)CPUCODE.BIN
3. ACPI table 03F49h(15.82K)01949h(6.32K)ACPITBL.BIN
4. YGROUP ROM 05590h(21.39K)038E3h(14.22K)awardeyt.rom
5. GROUP ROM[ 0] 04B40h(18.81K)02287h(8.63K)_EN_CODE.BIN
6. PCI ROM[A] 0E800h(58.00K)09358h(36.84K)MBIOS.ROM
(SP) NCPUCODE 07000h(28.00K)07000h(28.00K)NCPUCODE.BIN
Total compress code space = 48000h(288.00K)
Total compressed code size = 422CBh(264.70K)
Remain compress code space = 05D35h(23.30K)
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
6. PCI driver[A] 0E800h(58.00K)09358h(36.84K)MBIOS.ROM
7. Other(404E:0000) 064DCh(25.21K)01093h(4.14K)SN4IIP.BMP
8. Other(404F:0000) 065CCh(25.45K)01658h(5.59K)SN4P4P.BMP
9. Other(4050:0000) 065CCh(25.45K)017D5h(5.96K)SN4P4HT.BMP
10. Other(4051:0000) 08124h(32.29K)01DB2h(7.42K)SN4P4E.BMP
11. Other(4052:0000) 08124h(32.29K)01ECDh(7.70K)SN4P4HE.BMP
12. Other(4053:0000) 065CCh(25.45K)0141Bh(5.03K)SN4ICPD.BMP
Total compressed code size = 3B2CBh(236.70K)
Remain compress code space = 0CD35h(51.30K)
AwardBIOSDeco, version 0.2 (Linux)=-
AwardBIOS information:
FileLength : 60000 (393216 bytes)
FileName : 48pv110.bin
Decompression : 4BF00
BootBlock : 5E000
First Module : 0000
ASUS? : NO
| # Name Description FileOffset Ratio ID |
01 ( BIOS.BIN) [ MainBIOS ROM]: 000000h, 63%, 50000000
]: 0145B9h, 71%, 407F0000
]: 026D92h, 45%, 40290000
]: 029019h, 63%, 40860000
]: 032371h, 16%, 404E0000
]: 033404h, 21%, 404F0000
]: 034A5Ch, 23%, 40500000
]: 036231h, 22%, 40510000
]: 037FE3h, 23%, 40520000
]: 039EB0h, 19%, 40530000
02 ( awardext.rom) [ User-defined
03 ( CPUCODE.BIN) [ CPU micro code]: 01CD99h, 97%, 40010000
04 ( ACPITBL.BIN) [ ACPI Table]: 021B66h, 39%, 40030000
05 ( awardeyt.rom) [ YGROUP ROM]: 0234AFh, 66%, 400E0000
06 ( _EN_CODE.BIN) [ User-defined
07 ( MBIOS.ROM) [ User-defined
08 ( SN4IIP.BMP) [ User-defined
09 ( SN4P4P.BMP) [ User-defined
10 ( SN4P4HT.BMP) [ User-defined
11 ( SN4P4E.BMP) [ User-defined
12 ( SN4P4HE.BMP) [ User-defined
13 ( SN4ICPD.BMP) [ User-defined
Total Sections : 13
Три разных вывода об одном и том же образе BIOS
Что можно удалить, чтобы впихнуть известный модуль VIA VT6421 (6421v431.rom 62KB) ?
