автор почитал. The ISL6334, ISL6334A actively monitors output voltage and
current to detect fault conditions. Fault monitors trigger
protective measures to prevent damage to a microprocessor
load. One common power-good indicator is provided for linking
to external system monitors. The schematic in Figure 10
outlines the interaction between the fault monitors and the
VR_RDY signal.
VR_RDY Signal
VR_RDY signal.
VR_RDY Signal
