Dr.Rer.Nat писал(-а):commonly, CPU_RST# has a pull-up resistor connection to +GMCH_VTTTo VTT_OUT_LEFT. Dr.Rer.Nat писал(-а):a measured resistance values from CPU_RST (pin "G23" at LGA 775) to ground and to GMCH_VTT outputIf CPU not present, then "to VTT_OUT_LEFT".
