вот отчет powerstrip:
Diagnostic report - generated on 29.04.2005 ------------------------------------------------------------------------------ PowerStrip build - 457 Windows build - v.5.0.2195.2.Service Pack 4 DirectX build - v.5.1.2600.881 built by: Lab06_N(mmbuild) OpenGL renderer - GDI Generic, v.1.1.0
System board ------------------------------------------------------------------------------ CPU speed - 335 MHz Type - Intel i440LX-ITE867-2A69JF9FC-00 BIOS - Award Bios, 10/10/2003 AGP aperture - 64 MB AGP transfer mechanism - Отключено (desktop sharing?) AGP non-local memory - (n/a) AGP revision - 1.00 AGP transfer rates supported - 1x, 2x Current AGP transfer rate - 2x
Graphics card #1 ------------------------------------------------------------------------------ Identity - S3 Display controller Memory clock - 90,38 MHz Engine clock - (n/a) IRQ - (n/a) AGP revision - 1.00 AGP transfer rates supported - 1x, 2x Current AGP transfer rate - 2x Sideband addressing - (n/a) Display driver - s3t3d2x.dll, v.5.1024.530.0005 DirectX driver - s3t3d2x.dll, v.5.1024.530.0005 Attached monitor - Default Monitor (Microsoft) Monitor caps (1) - 1600x1200, 75kHz, 85Hz
Device enumeration ------------------------------------------------------------------------------ S3 Display controller (8A135333h) Intel CPU-to-PCI/AGP bridge (71808086h) Intel PCI-to-PCI/AGP bridge (71818086h) Intel PCI-to-ISA bridge (71108086h) Intel IDE controller (71118086h) Intel Universal serial bus (USB) (71128086h) - using IRQ11 Intel Power management controller (71138086h) Powermatic Ethernet controller (813910ECh) - using IRQ3 Avermedia Video device (036E109Eh) - using IRQ7 Avermedia Multimedia device (0878109Eh) - using IRQ7
OpenGL extensions ------------------------------------------------------------------------------ GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
Говорит, что некоторые функции отключены, но как мне их включить, если они поддерживаются?
System board
CPU speed - 335 MHz
AGP revision - 1.00
Sideband addressing - hardware support, but currently disabled
Fast write protocol - (n/a)
AGP texturing - hardware support, but currently disabled
Graphics card #1
IRQ - (n/a)
AGP revision - 1.00
Device enumeration
OpenGL extensions
GL_WIN_swap_hint
GL_EXT_bgra
