Вот они: BIOS Patcher ver. 4.23. Attention! Advanced qualification
Вот они:
Found 2Mbit BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support           : -> fixed.
1a.Bus Disconnect Support    : -> fixed.
2. XP frequency              : -> fixed.
3. New Koeffs Support        : is not needed to be fixed.
4. 32Gb-problem              : not found.
5. Some HDD detect-problem   : not found.
6. "MB"/"GB" string search   : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x  : not found.
11.New Stepping Support      : is not needed to be fixed.
12.Tualatin L2-init error    : not found.
13.New Freq in Setup open    : found, but Unknown format!
14.Set "Y" as default on exit: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp  40.8%
Adding start.tmp  87.5%
Ссылка: chaintech.com.tw/download/7xmb/7aivlc10.exe
Шил с помощью Awdflash 7.71. BIOS после этого сбрасывал в default.
